Valve Cover Trouble
Cali smog test told me my ignition timing was off...so i went ahead and checked with a timing gun. Now i had to remove the cam cover which involved lifting the valve cover a bit. In doing so when i loosend the bolts one of the longer bolts broke off at the thread and the thread is lodged in there. Any recomendations on getting the thread out? Ive thought about taping the bolt but the bolt is fairly thin....
Re: Valve Cover Trouble (sead21c)
you shouldn't have to take the valve cover off to check the timing. As for getting the broken piece out, i suggest using one of those little extending magnets that you see in the check out bins in autozone or pep boys.
screw extracter https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Valve Cover Trouble (LSpimpTEC)
As far as a magnet goes...see the thing is the thread is still in the hole.....and as far as the screw remover..when can i get this interesting device u babble about? And i removed the cover for the camgear because thats the way i can check for tdc correct?
cmon guys i wana fix this setback qwik....need to go to honda tomorrow..help would be apreciated
So todays the day gota get that fixed. Where can i find a screw extractor? https://honda-tech.com/forums/images/smilies/emthup.gif
the hardware store? Ace? TrueValue? Walmart even.
