EM1 won't rev past 3500
Old 04-13-2012, 10:43 AM
travis b's Avatar
Default EM1 won't rev past 3500
basically my car has a gsr bottom and b16 head, bottom end is built for boost (cp 9:1, eagle rods, etc) well my turbo shitted out on me so I decided to throw a stock header, stock injectors, and a stock ecu on it so I could have something to drive. It drove fine for that day and the next day. I had it idling in the driveway and it all of a sudden died. Wouldn't crank back up. Put a working igniter in it, nothing. So I swapped the coils, and it started up. Okay but now it will NOT rev past 3500, it just hits limiter, aka limp mode. The CEL is on, but it will not flash when jumped. No clue why, it just will not.
short: CEL is on wont flash, cars in limp mode, what to do.
Old 04-13-2012, 11:24 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: EM1 won't rev past 3500
What happens when you plug a scanner in?
Old 04-13-2012, 11:27 AM
TriniSpeC's Avatar
What code is it throwing?
Old 04-13-2012, 02:53 PM
apexi_rsx's Avatar
usually has something to do with the distributor or crank positioning sensor
Old 04-13-2012, 06:48 PM
travis b's Avatar
Don't own one, might be able to check tomorrow or monday however.
As I said, it will not flash so I couldn't tell you.
The coil and igniter I just swapped in are from a dizzy that was removed about a week ago working. The car ran fine literally 3 days ago..
Old 04-14-2012, 08:29 AM
travis b's Avatar
up...
Old 04-14-2012, 09:05 AM
92cxhatch169's Avatar
what ecu did you put in?
Old 04-14-2012, 09:01 PM
travis b's Avatar
all fixed now
Old 04-14-2012, 09:47 PM
Former User's Avatar
Originally Posted by travis b
all fixed now
Bad ECU?
Old 04-14-2012, 09:53 PM
travis b's Avatar
Well I had a stock obd2b si ecu running it the other day when it ran fine, but i tried a obd1 chipped ecu with a b16 basemap on it and it cleared it up just fine.
Granny_shifter
18
09-17-2012 08:08 AM
jm95itr
10-29-2009 07:30 AM
darkstormcr
06-27-2009 11:08 AM
gfuller40
06-05-2009 01:46 PM
PaImportTuner
09-21-2005 10:41 AM
Quick Reply: EM1 won't rev past 3500
