valve cover need help cutting
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">CUT? Why? Exposed cams seem risky.
The cams are under the main part of the valve cover. The cams themselves will not be exposed. He's referring to the 2 inch section over the timing belt/cam gears. To allow access to adjustable gears without removing the valve cover each time...
Jigsaw with a metal bit. Clean up with a dremel.
Re: (ZeeSix)
what works really well.. if you can find them. Is a huge hole saw. clamp the cover down to a piece of wood so that the drill bit in the middle (to align/guide the holesaw) drills into the wood while cutting half a circle into the valve cover. Then do the same for the upper timing belt cover. You could also buy a half moon/laser cut valve cover...
http://www.topendmotorsports.c....html <-- I have always wanted one of these
Re: (tj CTR)
they're called moon cuts and machine shops can do them for you. diy is going to look jagged unless you spend a ton of time with a dremel to get the curve look right.
Re: (tj CTR)
thats how mine has been for the last year or so and i live back in the sticks. oh yea and i dont have inner fenders either. i haven't had a problem yet
Re: (doublejz)
it should be grand im looking for cam gears next the state of them ones.can i get the same honda paint for my cam cover or can i put champion white on it.
Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">that's crazy.
i hope you've somehow secured that a/c hose.</TD></TR></TABLE>
x2
But it looks like it turned out well.
x2
Re: (instrument)
looks like a ps hose to me
-joseph
-joseph
