Valve adjustment done!!! **FEW QUESTIONS**
If I'm getting some ticking does this mean some were tightened too tight?
After I did cylinder #1, I rotated the cam 90 degrees to the 9oclock position and did cylinder #3. I then turned the cam to the 6oclock position and did cylinder #4. I then turned the cam to the 3oclock position and did cylinder #2.
Is that correct?
Also I did'nt quite know how much "drag" to put on each valve.
Is that correct?
Re: Valve adjustment done!!! **FEW QUESTIONS** (Fighterinsnatch)
on a dual cam vtec ummm tight *** loose ***** (thats just how i remember) so .007 exhaust .006 intake
and it has to be at TDC so use an extension in the cylinder to see when its at its highest point
Re: Valve adjustment done!!! **FEW QUESTIONS** (ek forever guy)
I'll def run the seafoam today.
But the ticking came after I adjusted the valves. Its a light ticking noise (valve lash) Could this damage my motor?
Also, I just noticed yesterday that on my header I'm missing two bolts where the 4 meets the 2. Its a 4-2-1 header so I need to replace those bolts. Its weird because I had those in there relaly good and its lke they just fell out. Could this also possibly be causing a noise?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fighterinsnatch »</TD></TR><TR><TD CLASS="quote">
honda motors tend to have a ticking noise, even after you do a valve adjustment.
it's perfectly normal.
Re: Valve adjustment done!!! **FEW QUESTIONS** (philosofy1)
I'm not doubting you by any means but how sure are you about that? I'm just concerned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
it's perfectly normal.</TD></TR></TABLE>
Exactly
Everything you did was right. And no as long as you adjusted them correctly it will not damage anything.
Exactly
Re: Valve adjustment done!!! **FEW QUESTIONS** (Boostedb20EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostedb20EH2 »</TD></TR><TR><TD CLASS="quote">
Exactly
Everything you did was right. And no as long as you adjusted them correctly it will not damage anything.</TD></TR></TABLE>
Exactly
Awesome! Thanks guys
Don't you think that the ticking is kind of annoying though? lol
