valve adjustment
valve adjustment
would my car run like **** if the valves are out of adjustment? b16 has 110k on it ive had it since 70k ive never done adjustment and to my knowledge its never been done
Re: valve adjustment (freeshot350)
well I have the same motor and in the morning it sounds like a tractor but thats about it it runs fine. I am going to get mine done in like 2 weeks tho.
Re: valve adjustment (jit01)
If the valves are way out of spec then it will run like **** as compression wont be right. If there ticking its time to adjust, if there no then let them be.
Ek Forever y0!
Re: valve adjustment (Luserkid)
it's unlikely they need adjustment unless you can noticeably hear the ticking.
If anything it's hella easy just to check them, won't hurt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freeshot350 »</TD></TR><TR><TD CLASS="quote">would my car run like **** if the valves are out of adjustment? b16 has 110k on it ive had it since 70k ive never done adjustment and to my knowledge its never been done </TD></TR></TABLE>
Most motors it's supposed to be done every 15-30K. Usually ppl have problems with loose valves, which are noticable of course by the ticking.
However it's also possible to have the opposite problem with tight impacted valves; this happens from a mis-adjustment or from age/neglect.
While it's not common to have valves tighten up, it is a problem with some motors. CRV b20's were notorious for this when I was doing services. A lot of times the lower end-of-spec feeler gauge would not even begin to slide in there....The nasty thing with over-tight valves is that you are not tipped off by any ticking noise, it usually becomes a driveability or idle issue.
The only car I've owned where this happened was an EG w/ a z6. I was having odd warm idle problems where the car would stutter and almost stall when dropping revs (rolling up to a stop sign for example) After several days of screwing with the usual suspects, I was horrified to finally find my valves had been adjusted by the previous owner WAY too tight.
Adjust them at least every 30K
lilxvtecxpwr
11
09-17-2002 05:58 PM
