vafc2 initial setup HELP PLS
i have a em1 and need help on my initial setup.
1. setting the sensor number??? 2. i know this one hehe(# of cyl) http://images.honda-tech.com/set1//smile/emcrook.gif 3. checking the throttle voltage? select sensor chk and check the throttle sensor voltage in the accelerator fully closed status and accelerator fully open status?? 4. Setting the throttle sensor type??? Select car select. When the throttle sensor voltage is 0 v to 1 v in the fully closed status in the previous item, set the arrow to the upward direction. When the same voltage is 3 v to 5 v, set the arrow to the downward direction. When the arrow is set to the mark **, no correction is performed by the throttle position..???? 5. Setting the vtec type??? 6. Learning the throttle opening??? Hold the accelerator fully closed for about 10 seconds while turning the ignition on. After that, hold the accelerator fully open for about 10 seconds.?? when the manual says hold the accelerator FULLY CLOSED/FULLY OPEN? open means flooring it? and closed basically don't touch the pedal?? |
Re: vafc2 initial setup HELP PLS (JDM PRO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM PRO »</TD></TR><TR><TD CLASS="quote">i have a em1 and need help on my initial setup.
1. setting the sensor number??? 6 and 6 2. i know this one hehe(# of cyl) http://images.honda-tech.com/set1//smile/emcrook.gif 8 https://honda-tech.com/forums/images/smilies/emwink.gif 3. checking the throttle voltage? select sensor chk and check the throttle sensor voltage in the accelerator fully closed status and accelerator fully open status?? you dont need to worry abou that. 4. Setting the throttle sensor type??? Select car select. When the throttle sensor voltage is 0 v to 1 v in the fully closed status in the previous item, set the arrow to the upward direction. When the same voltage is 3 v to 5 v, set the arrow to the downward direction. When the arrow is set to the mark **, no correction is performed by the throttle position..???? For the throttle do the 10 seconds WOT and then 10 seconds off, turn off car and good (this is on the ON position not car on). For the Arrows you want up and to the right 5. Setting the vtec type??? dont touch that 6. Learning the throttle opening??? Hold the accelerator fully closed for about 10 seconds while turning the ignition on. After that, hold the accelerator fully open for about 10 seconds.?? look at number 4 what i said when the manual says hold the accelerator FULLY CLOSED/FULLY OPEN? open means flooring it? and closed basically don't touch the pedal??look at number 6 for what i said</TD></TR></TABLE> |
