VAFC install problem,, need colors for the wires!!
i have a 99 civic si wiring harness for my car becuase i have a 99 Ek with a GSR swap. the diagram they show for the pins and what wires to tap into are super blury and suck ***. can anyone tell me the colors on the wires that i have to tap into and what their function is,, **** would be soooo nice if they did it like this.
..green wire with yellow stripe,---VTEC solenoid
thats the only one i know,, if they had a brain they would make their stupid manual like that.. sorry for the rage, but it pisses me off. if anyone could help me out, THANKS a TON! im off to see if the factory manual for the 99Si has a schematic that has color codes they way it should be... thanks
Re: VAFC install problem,, need colors for the wires!! (JDM CRX)
http://www.bseries.net/html/garage/vafc.php
Go here. We've got a wire color chart up too. At the time, we did not hook up the VTM wire. Make SURE you connect it otherwise you may have problems. If you have any questions, feel free to email or PM any of the Bseries guys. You can also get the instructions in .pdf format off of http://www.apexi-usa.com (under the documentation section). Good luck.
[Modified by ajm_00Si, 8:58 PM 7/12/2002]
