V-afc how hard is it to tune w/ it?
I am going to be boosting and was thinking about getting one. I was wondering how hard is it to tune with one?
Re: V-afc how hard is it to tune w/ it? (Bimmerman)
With out a wide-band, its pretty dam hard. Also if you really mess with the fuel curve on the vafc, it will also alter your timing.
Re: V-afc how hard is it to tune w/ it? (Lmgrcivic)
Blue Wire tune? Care to explain that?
I have a VAFC as my management, its really easy to tune with provided you have a wideband and datalogging (or a dyno). At first i didnt understand it but when i saw my tuner tune my car with it it all made sense and is very easy.
Risky Business
Re: V-afc how hard is it to tune w/ it? (Luserkid)
After going from the VAFC hack to Uberdata, I have to say that car feels a ton better with an uberdata basemap than it did on the hack.
You can tune a VAFC very easily, just get a wideband and edit the fuel curves until your WOT ratios are around 12:1, and your partial throttle and idle ratios around 14:1
Well I can't seem to do it very well.
I have hondata but been trying to save on fuel so I have been playing with it a bit. Only below 3500 rpm though-basicaly daily driving stuff. I really only left it on to use the display but hey since it's there I'm using it!
I got it tuned to use less gas in vacum but as it aproaches boost it goes very lean until it actualy is under boost.
I really need to get it tuned properly once I finish with the new toys. have them set it alot leaner under vacum.
Re: V-afc how hard is it to tune w/ it? (turboman)
im thinking that the blue wire tune is to run the 02 sensor output to the afc and the unit reads the voltage and tell u approx what your a/f ratio is....
ITR 01-0840
01-07-2002 04:59 PM
