use p30 ecu with usdm b16a2 motor
My problem is im swapping my engine out of one of my cx's hatches. And was going to use a b16a2 jdm bottom block with a usdm head and wanted to use a p30 ecu with it. So i would not have to change the harness would there be any problem with it and if so what do i have to do to use it.
Re: use p30 ecu with usdm b16a2 motor (spoonspeed)
I've got the factory B16A3 in my Del Sol and I've been contimplated picking spare B16 motors, just in case I blow mine. I was told that all B16 motor's/parts were interchangeable with each other, I'm not sure about the B16B's though...
To pass California Smog, you'd need to use the USDM intake manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonspeed »</TD></TR><TR><TD CLASS="quote">My problem is im swapping my engine out of one of my cx's hatches. And was going to use a b16a2 jdm bottom block with a usdm head and wanted to use a p30 ecu with it. So i would not have to change the harness would there be any problem with it and if so what do i have to do to use it.</TD></TR></TABLE>
It'll work. All are configured for B16 and same fuel maps just mainly different OBD's.
You will still need to wire up VTEC & Knock.
Re: use p30 ecu with usdm b16a2 motor (DelSolSiR)
sort of off topic.... the B16B is actually a destroked 1.8L R motor. If you measure the deck height of the b16b is identical the b18c5. 7mm higher then the b16a
Re: use p30 ecu with usdm b16a2 motor (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">
You will still need to wire up VTEC & Knock.</TD></TR></TABLE>
i thought the p30 did not look for the knock sensor
9jdmcivic8
02-03-2011 02:59 PM
stripes777
04-13-2006 09:01 PM
