urgent help needed, motor mount problem
Hey all,
My karma continues, just like every other project i undertake with my car. So i went to take off my first torque mount so i can install new ones, taking off the FIRST bolt.
I was having a little trouble getting it to come loose, and then disaster struck. The little nut welded inside the frame broke loose. now the bolt spins, but i can't get it out.
I need help!!!! what do i do??? is there some way i can get access to that nut?
Re: urgent help needed, motor mount problem (s1ngle)
stick a screw driver or something at the other end while you spin the bolt out
well if you can't get it loose you'll probably just have to cut the bolt off and weld another nut where the one broke off
Re: urgent help needed, motor mount problem (JDM PRO)
see, i can't really get to the other end... i need more insight on this....
has this ever happened to anyone?
Mr. Em1
07-18-2009 04:14 PM
Linh.
25
09-24-2006 06:58 PM
