Upgrading my ECU, but what next?
Im kind of new here, so I apologize if this is a noobish style thread... I'm somewhat new to the world of upgrading an engine and I am currently interested in building my D16y8 without using turbo (for now) and so far I'm at the stage of just doing the bolt-ons (I/H/E). So far I've managed to install an intake (Password JDM carbon fibor intake) which probably seems ALOT more than necessary. And a catback exhaust BUT I still have a stock header. Right now I'm waiting on receiving a DC stainless steel 2 piece headers and was interested in upgrading my ECU. I have very little education on what ECU to get for my D16y8 and was wondering what were my options for the time being.
I know that I don't have much to gain at this point since I haven't messed with the Pistons and basically the overall engine..but maybe someone can shine a light of what I can get with the ECU at least? I know it depends what you want and all...but what's good for the time being..if there is a certain setting maybe? Help.
Just as an addition, I know people ask "What do you want out of your engine?"....My response is "Make simple power" I guess?
Re: Upgrading my ECU, but what next?
Before you go diving into the tuning options, where you do live? If you're anywhere that requires a plug-in scan for inspection (all of California, as well as most major cities and surrounding areas), just stop right now. Every enhancement option will make you fail that, period.
If that checks out, you have two options. Option A is a socketted and chipped ECU. Option B is a stand-alone tuning system. Which one is right for you ultimately comes down to goals and budget. I can say right now, you'd be fine with option A.
I live in Wisconsin.... So no issues on the whole carbon thing and the only problem have to worry about is winter, which is finally turning to spring. So chipped ECU is my option on that, what type of ECU is good if you dont mind me asking..? P28? and I've heard of "Chrome" in terms of chipped ECU.
By budget isn't too stiff. Although I wouldn't dig as deep in pocket as those to pay for their K24 and start taring up shi**.
Unless your adding a turbo or going dohc i wouldnt mess with you ecu to much. You will spend more money trying to get nice power outta that sohc n/a than its worth. Just start putting together a dohc swap or turbo setup. Jmho
It wouldn't be worthless at all. From the factory, our cars are "tuned" for fuel efficiency and longevity - a chipped and tuned ECU, even on a completely stock car, will still get you more power across the band. There are two ways you can go about tuning your car as it is.
Option 1 involves all the necessary hardware, plus $300-$500 for a professional to tune your car on a dyno. Since you're running basic bolt-ons right now, it should be a quick and painless, it'll just cost you a small chunk of change.
Option 2 involves all the necessary hardware, and your willingness to learn. A lot. You'll need a socketted ECU, a quality wideband O2 sensor, a laptop, and a Moates Ostrich (or similar). You'll want to do a lot of reading and learning on how to tune a motor, and then dive in. With your laptop and Ostrich, you'll be able to datalog and tune the car yourself on the road (or even in your parking lot), and you'll need the wideband O2 sensor to make sure your engine is running at safe AFRs.
The plus side of option 2, other than saving a couple hundred bucks, is when it comes time for you to get another motor, or boost, or build, or whatever you end up doing, you'll be able to tune it yourself, saving yourself more money in the long run. Also, a basic bolt-on D16 is quite possibly the best platform for learning how to tune AFRs, ignition timing, and all the other fun stuff that goes into making a car go faster.
Yep, these guys are all over it- don't waste any more on sohc- takes a few bank loans to make any power- start w/dohc. Way more potential in long run
I asked pretty much the same question... I have a d16y8 and wanted some advice on what i could do. All you'll get from these guys is " sohc isn't worth anything" "go dohc" "bolt ons dont do ****" you're better off doing the research yourself apparently no one on a ek thread does anything but turbo or swap
according to these guys just throw your d16 in the trash.
its ******* frustrating! I'm not trying to put mine on the track. I'm just trying to play around with my DD. This site sux for guys trying to learn
been there done that
do you know how many times in the 10+ years this site has been around that that exact "what intake/header/exhaust should i get?" question has been asked?
If you loved me, you'd all sell me your magic cards to me today
I'd say the best option for OP would be to just get a standred basemap chip for his Y8 with bolt on's. The other's that have ben listed are great especialy if you are planning to go all out or beyond bolt on's. but the money spent trying to build a N/A d will leave you dissapointed with the end result as said many times on H-T.
saintsfan you got good advice....
The Grumpiest
With all due respect what makes ME mad is that people put together a cache of info like this and new people refuse to read it and then have the nerve to get frustrated because no one wants to ask the same question that's been asked for the one-millionth time.
If people are telling you that D-series are WORTHLESS in their naturally aspirated form then you can take that to the bank. If you don't have THOUSANDS to drop into one to barely make 150-160hp then IT'S NOT WORTH IT!!! IMO even a chipped and socketted OBD1 ECU on an engine with basic bolt-ons is a lesson in frustration. You don't make any real power to be noticeable. And if your butt-dyno says you are, you'll soon crave more and then what? Do you think people are saying this just to frustrate you? That they're sitting on info and not wanting to give it up? Preposterous. If you don't want to turbo it and you aren't boosting it then just move along because you're just wasting time. This aint the Fast and the Furious.
Are you kids not reading my posts? D series motors aren't completely worthless - they're a good learning platform, especially if OP wants to learn how to tune his own ****.
Op- how much do you want to spend on ecu? Do you want to use it in future for another engine/boost?
The Grumpiest
Let's dispel the myth the OP seems to have that simply plugging in another ECU will somehow gain him more power because I think that's part of the misconception he's having. It does not work that way.
I can read just fine you said either a "chipped ecu" oem style or ostrich as stand-alone. I would be stupid to assume op "new to HT" knows what either of these mean?? He's new to this, he doesn't know where to look/which to buy, he's asking for direction. We know where/what you mean, but I'm sure he doesn't, don't take me asking you what you're recommending as being a smart/dumb ***.
Dude, back off- the guy wants a recommend, not mind-blowing explanations of how tuning works. Save the insults for the guy in the mirror. And, yes, I do know a handfull of tuning on my S300. Got it?
"Back off"? You're the one trying to get information spoon fed to you. That's not what we do here. I'm also not insulting anyone, but if you'd like me to start, I can point out my doubt in your "tuning" purely based on your complete lack of abilities with the English language.
If you aren't going to be helpful to anyone, get out. I'm not going to sit here and point out every mistake you've already made. The OP asked a question, I very specifically answered that question, with multiple options for the OP to take. You've given nothing beneficial.
