Undiscussed ITR 5 bolt question...
After searching i didn't find any information on this but does anybody know how much weight i'd be adding on with a 5 bolt conversion with the itr rims, on my DX hatch after swapping the front discs and rear drums and steelies. What's the diff in weight approx?
[Modified by 1.8 HB, 4:56 PM 10/8/2002]
Re: Undiscussed ITR 5 bolt question... (SkyeC)
Because i am going N/A and weight matters. If i was to go with turbo or something where weight isn't as crucial i wouldn't care, but i have stripped a lot of things out of my car and i would hate to see the ITR 5 bolt make up all that weight. All my work out the window in a way.
Re: Undiscussed ITR 5 bolt question... (1.8 HB)
bwwwuuuuuuuuuwaaaahahahahhaaaaaaaaa
"crucial in my case"
LOL....
really.
believe us when we tell you a 5 lug swap is all worth it if you are into any type of racing or driving OTHER THAN DRAGGING.
LOL....
really.
Re: Undiscussed ITR 5 bolt question... (owen_the_soyboy)
Ok, we have that down, it's worth it, suspension/braking power, blah blah i understand that clearly. HOW ABOUT THE WEIGHT?
if you wanna know the EXACT weight why dont you buy the parts and weigh them all before the install.
I myself have taken all the steps to lighten my car extensively , becasue a lighter car will handle better on the track (which is where it spends alot of its time) but not once did I even think about the weight I was adding when I put my larger brakes on or rear swaybar
you NEED brakes to stop.
it is weight you shouldnt be concerned with.
Re: Undiscussed ITR 5 bolt question... (Doctor CorteZ)
You are right, and i totally agree. I am most likely going to go through with this as i am getting a great deal on the whole suspension...but there is nothing wrong with being curious.
Well, i am using OEM pads, the fluid was flushed twice already in attempt for better pedal feel I was wrong, after flushing the brake fluid (properly both times) in a 3 month interval i didn't seem to get the results i wanted. Either way it's time to upgrade, the front discs are not cutting these days. Also, after racing, for example, after 3 runs, one right after the other up to 170-180 km/h my brakes give up completely. They barely stop, i am assuming because of the heat. It's so bad that it feels like i DON'T have power brakes.
Can't remember what fluid it was, bought it at a local automotive store. What are the best pads out there for the price? Hawk HP is good from what i hear, but kind of pricey.
Solbros Owns Me
why not just upgrade the fronts to GSR brakes, and the rear to 92-95 Si discs, or leave the drums. This should slow you down fine. I don't care what size rotor/caliper setup you have going. It's the pads that's doing the stopping.
