Timing Belt?
Old 01-12-2010, 09:31 AM
Rick1t's Avatar
Default Timing Belt?
I have a 96 Civic, approaching 180K
When do I need to change the timing belt again?
Second question.....I have a small exhaust leak near/at the manifold....when the car warms up it's gone. Is this something to worry about?
Thanks
Rick
Old 01-12-2010, 09:46 AM
deadazleep's Avatar
Default Re: Timing Belt?
should be changing the belt for the 2nd time, i was always told the belt was for 90k but of course it can last longer and maybe not even as long
Old 01-13-2010, 12:12 PM
Rick1t's Avatar
Time wise how long does it take to change out a belt? It's pretty cold here in Michigan....
Old 01-13-2010, 12:23 PM
sde780's Avatar
2 hours if you know what you're doing.
2 days if it's your first time
exhaust leak could make you run rich and give you crappy gas mileage
Old 01-13-2010, 12:28 PM
itsnotfast's Avatar
^Lol.
Old 01-18-2010, 07:38 AM
Rick1t's Avatar
I'm pretty handy......I'm not as young as I used to be but....I can still turn a wrench....Last week I changed out an CV axle on the wife's van.
Should I plan on replacing the waterpump at the same time?
Thanks
Rick
Old 01-18-2010, 07:54 AM
RotaryPWR's Avatar
ya, definitely do the waterpump too.
changing the timing belt can be a pain in the neck, especially the first time, and it is a little scary because messing up can be very costly. just be sure to follow the steps PERFECTLY and then check and recheck all of your work.
and then check again
Old 01-18-2010, 08:11 AM
starion88esir's Avatar
It wouldn't be a bad idea to replace the thensioner either. I usually do every other timing belt change. Nothing is worse than replacing the belt and a few months later the tensioner fails and you're back two steps. I've seen it happen enough.
Old 01-18-2010, 09:19 AM
boxeocampeon's Avatar
Thanks
Rick
i would def do the waterpump also since its right there
Old 01-18-2010, 12:53 PM
komat's Avatar
get the timing belt kit where it comes with a new tensioner water pump and gasket
they run for about 100 or 150 i forget
if you know what you doing takes 20-30min or hours if you dont
https://honda-tech.com/forums/showth...ht=timing+belt
thats one place that does it do a search for others
Old 01-18-2010, 01:41 PM
thumper64's Avatar
the hardest part is getting the crank pulley off. After that, it's nothin.
Old 01-18-2010, 01:53 PM
cleansi's Avatar
x2
Old 01-18-2010, 02:52 PM
Nichelson_Performance's Avatar
yup i've got it down to around 20 minutes with the complete procedure
Old 01-18-2010, 03:22 PM
94civiccupew/b7's Avatar
God damn!! you must be driven around with no upper motor mount an no timing belt covers
Old 01-18-2010, 03:27 PM
thumper64's Avatar
Or he's using air tools and does it a bunch. A friend of mine said that Honda techs can do a head gasket in 15 minutes. Apparently some people can pull a motor in like half an hour.
Old 01-18-2010, 03:36 PM
yes i do it a bunch, but i only use an impact gun to remove the crank bolt.
i change my timing belt once a year due to the fact i don't want my investment going down the drain cause of a stupid timing belt
Old 01-18-2010, 03:37 PM
lthao61's Avatar
maintenance record book or every 90k miles, sooner if in extreme conditions
Old 01-18-2010, 03:42 PM
EL Vap133's Avatar
LOL, I was going to say the same thing.
Old 01-18-2010, 04:10 PM
Mhondatech's Avatar
i an a honda tech its possible
also on ur exhaust leak those cars crack manafolds all the time
nursepaige
08-26-2009 06:49 AM
dunkd
05-27-2005 07:48 PM
BlackGser
04-27-2005 11:00 AM
Quick Reply: Timing Belt?
