uberdata question??
uberdata question??
Right now I am currently runnin an obd2 ecu, but soon i'm converting to obd1 to run uberdata, but I was wonderin if you are able to use the uberdata dataloggin with the obd2 ecu, because it has the same area to attach the datalog cable
Re: uberdata question?? (mwieczorek43)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwieczorek43 »</TD></TR><TR><TD CLASS="quote">Pretty-sure you cannot run Uber with OBD2.
I do not know for sure </TD></TR></TABLE>
you cant.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gSIr »</TD></TR><TR><TD CLASS="quote">Right now I am currently runnin an obd2 ecu, but soon i'm converting to obd1 to run uberdata, but I was wonderin if you are able to use the uberdata dataloggin with the obd2 ecu, because it has the same area to attach the datalog cable</TD></TR></TABLE>
That one im not to sure about. but i am going to have to go with a No on that one.
you cant.
Re: uberdata question?? (sohcvtec1995)
Nope...it will only run on an OBD1 ECU, that is running Uberdata code (meaning, you cant even datalog a stock OBD1 ECU unless it is chipped and running an program made by Uberdata)
averyvm
07-09-2007 12:23 PM
