Type R piping on an 92-95 hatch........??????
im wondering if i can use stock type r exhaust piping on my eg......
powerplant is a b18c5r so i know it will bolt to the header but do the bends and hangers connect to the ones on the civic hatchback chassis?
also i tried searching but i couldnt find anything?
Re: Type R piping on an 92-95 hatch........?????? (acuracing)
I used ITR piping on my car, just the B-Pipe though. So basically ITR cat all the way back to where it meets the axleback. I had a muffler and axle back pipe welded together since the ITR muff and everything doesn't fit without modification. The B-pipe though did match up to the EG hangers and fit fine.
got a c5 head and l used the jdm 4-1 header type 1 racing cat jack tanabe b and c pipe and have a eg6 spoon n1 sounds deadly
all other parts are for a type r except the n1 muffler because of the trunk lenght.
Re: Type R piping on an 92-95 hatch........?????? (TDReh2)
If you use ITR header+cat+b pipe it will bolt up..You'll have to use the b pipe and cat at the same time as the cat is 5cm longer than the cx/vx/si cat (and thus the b pipe is shorter)
Re: Type R piping on an 92-95 hatch........?????? (ce)
Well all I have is the muffler with the section of piping that comes attatched to it. So the rest will all be made at Mufflerman or wherever I go to get it done. So How should I tell them to hook it up? What size piping is the axleback portion???
thanx for all ideas so far
Dc295kid
09-23-2008 10:33 PM
