Type R intake on a b16 engine
New User
want to know if you guys think a itr manifold is worth the $$ on a b16a
and if anyone has one what was the results?
New User
Re: Type R intake on a b16 engine (ITR607)
Best performance for NA b16a. Cost wise.
Here is why, thanks Lyonel...
"The main differences of the Type R intake manifold as you can see from these pics are:
- bigger plenum
- plenum sits lower which enables the intake charge a more direct path to the intake ports
- shorter and fatter runners = top end power"
http://lyonel.8m.com/rvsb16a_im.htm
- bigger plenum
my b16a3 put down 154 hp to the wheels with this intake,i used a comptech header and aem intake,i know they didnt make a huge difference so im assuming the intake manifold did,id say that it is deffenetly worth it ,especially if you ever go turbo.order the type r throttle cable and bracket too,they are about $15.
I have the ITR manifold on my B16A, and i like it. It will perform better when i get higher compression and hi-lift cams!!
New User
Re: Type R intake on a b16 engine (neof69)
thanks guys .. i bought a01 itr cams for it already but was unsure if the manifolod was worth it .. i have a big bore throttlebody that i want to trade for a stock itr
one i think the throttle body would be to much over kill what do you think?
GearheadzAuto
10-22-2015 12:13 PM
robbys89
04-10-2010 09:30 PM
christian7750
03-16-2009 06:50 PM
solofthesouth
05-18-2006 09:06 PM
