type r cams can be installed on eg?
i have a little question, i have a type r cams, will this fit on my 93 civic eg? tnx.
well by the way if ever you need honda parts and accessories i do have some of it here. just tell me what you are looking for and how much for it? thanks.
Electrician
By the way you sound, it seems you have a stock motor in your hatchback. If you do, you can't. Type R are DOHC VTEC motors and you probably have a SOHC non-VTEC (unless you have a VX) motor.
Re: (hondapartz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapartz »</TD></TR><TR><TD CLASS="quote">yup i do have a b16A ef engine. dohc vtec. i have installed it on a eg.</TD></TR></TABLE>
Then yes, you can install the type r cams.
Re: (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 »</TD></TR><TR><TD CLASS="quote">you will need to upgrade your valve springs to ITR springs at a minimum</TD></TR></TABLE>
I would also suggest that you upgrade your valve springs and insist that you do so if the engine was originally mated to an auto trans (since the auto b16's had single valve springs on intake and exhaust side) If you don't have the cash though, the stock dual valve springs will hold up to stock redline. Just don't mis-shift.
