TYC EG One-Piece Projectors - Signal Bulb Number?
I am trying to find the number of the signal bulb that comes in those TYC one-piece projectors for eg hatchs+coupes. I want to find some sort of a replacement bulb to put in there, but it is near impossible to get the bulb out without removing the entire headlight. With my luck it would probably be some weird number that no one is going to stock.
That said, if someone has a set of these headlights out, has access to looking at a set, or just knows for some reason, I would greatly appreciate any help you could give me.
Thanks.
Thanks.
Re: (5ltreater)
H1's and H3's for the turn signals?!
Again, I don't know everyone is ready my question right.
I want to know what number the signal lights are.
Not the headlight bulbs... the signal light bulbs.
The headlights came with them already in there.
Now that I got it all installed its a lot of work to get them all out.
If anyone knows and could help me out, that would be great.
Re: (Mikerosoft)
I finally got the bulb out. It is a 2357A.
But I need to replace it with either a 2057A or 1157A.
I figured I would put the specs of the two other up and if anyone can tell me which would work best I would greatly appreciate it.
This is what I have:
-----------Design Volts-------Design Amps------MSCD-------Rated Life
2357A--------12.8-----------------2.23-------------30-------------400
----------------14------------------0.59-------------2.2------------5,000
I need to replace with either a:
2057A--------12.8-----------------2.23-------------24------------1,200
----------------14------------------0.48-------------1.5------------5,000
or
1157A--------12.8-----------------2.1--------------24------------1,200
or
their all 57 series so their all dual filament.. the only difference will be the bases....you can try buying a set of each and seeing if it can fit in... and if it dosent then just return the bulbs....but im pretty sure the 2057 will fit.... Good Luck!
Vincent.
06-14-2004 09:09 AM
INVALID
10-08-2002 05:48 AM
