Two TOKICO Illumina installation questions
I received a set of TOKICO Illumina shocks today for my 1997 Honda Civic EX. Each shock came with . The instructions say that is how I should install the above five parts. Is that correct? Also, the rear shocks came with bump stops. Should I use those or the stock ones?
Re: Two TOKICO Illumina installation questions (One-Panda)
Yes that is correct...
Cut your stock bump stops in 1/2. (They came with new ones?)
-Alex
[Modified by 2kTypeRHatch, 5:46 PM 1/10/2003]
-Alex
Re: Two TOKICO Illumina installation questions (2kTypeRHatch)
-Alex
-Alex
Re: Two TOKICO Illumina installation questions (Del)
I cut the stock bump stops when I installed the Eibach Pro-Kit. Not all four Illumina shocks came with bump stops. Only the rear ones did. I wonder why.
Re: Two TOKICO Illumina installation questions (DC Sports EJ8)
Install those upper pillow mount bushings like your diagram..it is correct. It should be exactly how you took the original ones off also.
For the bumpstops:
Cut off 1/2 of the original bumpstop for the two front struts. The rears use the Tokico supplied bumpstops.
For the bumpstops:
Re: Two TOKICO Illumina installation questions (SLPR)
I thought, but don't remember off the top of my head, but I thought the bottom one is supposed to be in the same direction as the top bushing. Like I said, i THINK that's how its supposed to be...but i could also be very wrong, I havent assembled suspension in a few months, it's been a while
Re: Two TOKICO Illumina installation questions (b16a ferio)
My KYB AGXs had rear bump stops as well, but the front didn't. I decided not to cut my bump stops. I used Comptech springs which is prety much the same drop. I would just leave them, since Tokico struts are the same piston length as mine.
