Turn Signals Acting Weird/Not working
Ok so it seems problems keep occurring with this hatch...its a 92 CX so my turn signals dont work...well here are my problems:
1.I turn on my headlights..my parking light ALSO come on and the Indications for my Hazards BOTH come on in the Gauge Cluster...weird..
2.When i hit my left or right turn signal my hazards come on..and sometimes the idle will drop or pick up when i hit the turn signal
3.And Sometimes my turn signals wont even come on lol.
BUT when i hit my hazards they will come on and work fine..
Well i finally got around to replacing my Turn Signal Relay that is under the driver side dash and that didnt fix the problem...so im guessing i have to switch my hazard switch?
Re: (bdubnyc)
try the switch or possibly the actual turn signal/light turn on arm. I had a similar problem in an Integra with my hazards and I replaced the turn signal arm and it stopped. you can get one on ebay for like 7-10 bucks if the new switch doesn't work.
Re: (siguy9900)
its not the hazard switch dude, im going through the same pain in the *** head ache right now, im about to just swap over a whole new fuse box and harness! this **** is pissing me off to no end!! and no one knows how to fix it
Re: (Bob_760)
Hey dude, I am not actually a honda guy, but I am an electronics engineer and a fairly decent car mechanic so here is my take on this. Sounds like possibly 2 things. Either the turn signal module that the arm goes in is broken or you have a loose wire inside your steering column. Since your hazards are comming on when you turn your turn signal on in either direction and all your hazards are in ANY car is both turn signals going at the same rate it sounds like the switch inside your steering column is faulty. I would replace that first and see if that works. Hope that helps.
Re: Turn Signals Acting Weird/Not working (bdubnyc)
Try replacing the turn signal bulbs. Mine did the same thing, and all it is, is in the turn signal bulb there are two wires, or prongs, or whatever you want to call them. One acts as a running light and the other as a turn signal. Well if you have a bulb in there that only has one prong it could just be shorting out everything and causing massive problems. Just try replacing them first.
Well also my dimmer switch went bad but im replacing that but at the same time..when that happend my Parking lights went out with my gauge cluster lights...and also my tail lights...BUT my brake lights work...what is the problem there too? is my parking lights not working part of my Tail lights not working?
Well i have a Interior and Under Hood Fuse box coming with fuses and a new dimmer switch and another Turn Signal/Headlight Arm coming soon..i was also told that the bulbs i installed could be 1156 Single Filament Bulbs in the 1157 Dual Filament Socket...could that be a possible problem too? i need to get Dual Filament Bulbs?
