Turbo or Swap?
Old 03-12-2008, 04:59 PM
zachattack54's Avatar
Default Turbo or Swap?
I got a 92 delsol sir with a B16 and I am looking for some more power. Im considering either turboing it or swaping in a ITR motor. Both will cost "roughly" the same.
Things I have to consider
Reilablity
MPG
Power
resale
Im sorry for the Cletia(sorry I can't spell) thread but im in a perdicament and some opinions are needed.
Old 03-12-2008, 05:48 PM
blwn95civic's Avatar
Default Re: Turbo or Swap? (zachattack54)
Well swapping to a itr motor wouldnt be worth it IMO cause you will be buying a whole new motor for roughly 50 more hp... Or you could spend the same amount of money and have a safe 300whp daily driver.
If you go turbo.....
Reilability: If you do it right and use quality parts and do regular maintenance i dont see why you would have a problem with reliability. Just check fluids regularly and watch for leaks.
MPG: If you stay out of boost with a good tune you will yield about the same mpg.. but when you go boosting you can watch the gas hand go down.
Power: Stock block b series are good for roughly 400whp... wether you wanna push it that far on your first turbo build or not is up to you.
Resale: Either way your gonna be screwed here so go ahead and do what you want with it while you have it
Old 03-12-2008, 05:51 PM
2redstars's Avatar
do a good quaility turbo setup. even on a stock motor, it will better than an itr swap.
Old 03-12-2008, 06:20 PM
onsetofpurity's Avatar
Turbo a swap?
Old 03-12-2008, 08:26 PM
thegoudster's Avatar
i'd probably go for the turbo. as much as i love the sound and feel of a type-r i think you could do a solid turbo setup for significantly less dollar wise.
as far as reliability, i've got one buddy that just pulled the turbo kit off of his motor after 40,000 miles. he built it well and took care of it, only pulled it off to put a bigger kit on.
as far as resale... cars are not an investment. if you want to put money into it that's up to you, but don't expect to get more than 1/2 of it back, and that's if you're lucky.
Old 03-12-2008, 09:51 PM
queda's Avatar
throw in a built ls bottom end, gsr cams and boost it.
Old 03-12-2008, 10:47 PM
Gamefreak0109's Avatar
boost it. you will get more power for the same price....
Old 03-12-2008, 10:49 PM
Unceasing Measure
Archidictus's Avatar
Default Re: (Gamefreak0109)
Turbo or swap?
Both
A swapped Civic is not fast, a boosted SOHC Civic isn't fast, but a boosted-and-swapped Civic can be very, very fast
Old 03-12-2008, 10:51 PM
he has a B16.....DOHC, no SOHC
Old 03-12-2008, 10:56 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gamefreak0109 &raquo;</TD></TR><TR><TD CLASS="quote">he has a B16.....DOHC, no SOHC</TD></TR></TABLE>
My statement stands.
Old 03-13-2008, 10:27 AM
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
My statement stands.</TD></TR></TABLE>
Haha thats wats up
outlawzsouljah
12-27-2009 01:16 AM
jmader19
03-05-2008 03:09 PM
jdmdc5integra
11
06-17-2007 04:39 PM
integrals957
05-31-2006 10:35 AM
allmotorsleepingcivic
05-15-2006 08:30 PM
Quick Reply: Turbo or Swap?
