turbo sohc vtec
turbo sohc vtec
i just finished my home made turbo kit and i tried using the hadata hack of the dsm injectors andit did not work then i went with a the check valves and the car is still running like **** i can only be on the gas around 30% throtell i am using 4 check valves it throws a map sensor code anybody have any sugestions thanks
Re: turbo sohc vtec (cxca64)
I can't be of help here but i know that some of the guys on the turbo forum might help. as well as the guys at the d-series board (different forum altogether) i just can find the address. i am sure that someone will post it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxca64 »</TD></TR><TR><TD CLASS="quote">i tried using the hadata hack of the dsm injectors </TD></TR></TABLE>
What? What the hell is the "hadata hack?" Never heard of it unless you mean Hondata. What engine do you have? Try a missing link instead of check valves.
Re: turbo sohc vtec (Daniel)
First off, can you re-write that in english?
second, what's your set up? did you use a resistor box or resistors for the fuel injectors? Its kind of hard to help you with such a vague question...
Re: turbo sohc vtec (greebler)
you need either a resistor box or inline resistors with those injectors. if you search on google.com for s-afc hack you will find a step by step how to for the wiring. it's really not that complicated. also, you DO NOT use check valves with the afc hack or smc hack....
i hope you're better at working on your car than at typing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxca64 »</TD></TR><TR><TD CLASS="quote"> i just finished my home made turbo kit and i tried using the hadata hack of the dsm injectors andit did not work then i went with a the check valves and the car is still running like **** i can only be on the gas around 30% throtell i am using 4 check valves it throws a map sensor code anybody have any sugestions thanks </TD></TR></TABLE>
He means he's using AFC Hack(I think). There is no need to use Check valves or anything for AFC Hack. All you need is an AFC, 450CC DSM injectors and an older honda resistor box or 10 ohm inline resistors from radioshack. Obviously you didn't set the settings right. Re-check your ****. https://honda-tech.com/zerothread?id=137901
