Turbo SOHC oil tap
Turbo SOHC oil tap
When you need to tap an oil source for the turbo--should I go from a pre-existing line (not sure which one, but there is one) or should I tap the stock oil pump.. if I go with the oil pump should I replace the stock with an upgrade...?
Also, Im wondering about numbers-- im looking towards a T3 turbo-- non-intercooled (for a short time) AEM intake, full custum 2 3/4 in exaust with a high flow cat. 370cc injectors, NGK plugs + wires, ??? hp numbers??
Re: Turbo SOHC oil tap (ProspectTuner)
My turbo feed line is tapped off of the oil pressure sending unit with a T on the back of the block near the oil filter.
