Turbo fuel ...help.
Turbo fuel ...help.
so i hav a D16Y8 turbo @7psi. orig. i was running a 255 Walbro and a Blox FMU. wich im not proud of. I finnaly decided to ugrade and im getting my ECU remade for the fuel curves for the 450cc injectors, and ill keep my 255 Walbro.. som people are telling my to get a regular FPR and som tell me to get a Rising Rate FPR...which one do i need or neither? if you guys are running a turbo D-series let me know what you hav found to hav the most MPG and power balance in a fuel system. Thanks!!
If you are getting your ecu remapped it should be for the factory regulator. All the rising rate does is add fuel pressure as boost rises. So unless thats programmed into you ecu you dont need it.
miguelJ
01-26-2017 05:01 AM
do i need an adjustable fuel pressure reg. if im running walbro 255lph with stock fuel rail on turbo
92gsrteg
08-25-2005 11:00 PM
DR. ON POINT
06-27-2001 06:25 PM
