Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Honda Civic / Del Sol (1992 - 2000)
Reload this Page >
Turbo d16y5 doesn't have fuel pressure when turned off. Only when running. Can you he
Old 07-06-2019, 04:54 PM
Default Turbo d16y5 doesn't have fuel pressure when turned off. Only when running. Can you he
I need help with my 97 Civic d16y5 turbo not having fuel pressure. I have an eBay kit installed and the regulator drops fuel when car is off
Civicjean is offline
Old 07-06-2019, 09:26 PM
muellersfan's Avatar
Default Re: Turbo d16y5 doesn't have fuel pressure when turned off. Only when running. Can yo
Eventual loss of fuel pressure is normal after turning off the engine.
muellersfan is offline
Old 07-07-2019, 01:07 AM
Jimster480's Avatar
How quickly is it dropping?
As muellersfan said; fuel pressure does drop over time as the engine is off.
Now if you turn the key to prime the pump and you don't see the fuel pressure go up... then that is something else entirely. Usually a problem with your FPR (assuming the fuel pump is working properly).
Jimster480 is offline
Old 07-07-2019, 05:10 AM
Does it run OK? Perhaps the presence of a gauge where it really isn't necessary leads to overthinking it.
> eBay kit
'Nuf said.
mk378 is offline
Old 07-07-2019, 08:57 AM
It drops really quick. Like instantly when I shut it off. I thought it was supposed to slowly drop when off. Also it runs alright but it bogs when I turn it on. Then it clears out and runs good. Maybe like timing is off or something?
Old 07-07-2019, 09:35 AM
The FPR may be bad.
Old 07-12-2019, 10:49 AM
Tomís's Avatar
Can post the pic when the key ON?
Tomís is offline
Old 07-12-2019, 08:04 PM
Freedo_Civegra's Avatar
Originally Posted by mk378 View Post
> eBay kit
'Nuf said.
What regulator are you running?
Freedo_Civegra is offline
  • Ask a Question
Question Title:
Description:
