Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Civic / Del Sol (1992 - 2000) (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/)
-   -   Turbo d16y5 doesn't have fuel pressure when turned off. Only when running. Can you he (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/turbo-d16y5-doesnt-have-fuel-pressure-when-turned-off-only-when-running-can-you-he-3338711/)
Civicjean 07-06-2019 04:54 PM
I need help with my 97 Civic d16y5 turbo not having fuel pressure. I have an eBay kit installed and the regulator drops fuel when car is off
muellersfan 07-06-2019 09:26 PM
Re: Turbo d16y5 doesn't have fuel pressure when turned off. Only when running. Can yo
Eventual loss of fuel pressure is normal after turning off the engine.
Jimster480 07-07-2019 01:07 AM
How quickly is it dropping?
As muellersfan said; fuel pressure does drop over time as the engine is off.
Now if you turn the key to prime the pump and you don't see the fuel pressure go up... then that is something else entirely. Usually a problem with your FPR (assuming the fuel pump is working properly).
mk378 07-07-2019 05:10 AM
Does it run OK? Perhaps the presence of a gauge where it really isn't necessary leads to overthinking it.
> eBay kit
'Nuf said.
Civicjean 07-07-2019 08:57 AM
It drops really quick. Like instantly when I shut it off. I thought it was supposed to slowly drop when off. Also it runs alright but it bogs when I turn it on. Then it clears out and runs good. Maybe like timing is off or something?
muellersfan 07-07-2019 09:35 AM
The FPR may be bad.
Tom’s 07-12-2019 10:49 AM
Can post the pic when the key ON?
Freedo_Civegra 07-12-2019 08:04 PM
Originally Posted by mk378 (Post 51965850)
> eBay kit
'Nuf said.
:uhoh:
What regulator are you running?
