Turbo for Civic!!
Old 08-09-2001, 10:53 PM
New User
LarsHonda's Avatar
Default Turbo for Civic!!
I am planning on buying a turbo for my 98 civic ex and I wanted to know how well the engine will hold up if I get the stillen turbo, revhard intercooler, and hks greddy types blowoff valve. the car has about 55thousand miles on it.
Old 08-10-2001, 12:24 AM
liam821's Avatar
Default Re: Turbo for Civic!! (LarsHonda)
i would highly recommend getting a thicker head gasket (2mm). That will lower the compression some and help with detination. Remember boost does not kill an engine, detination does. I would also get an aftermarket ignition, say a MSD.
With the head gasket and a good fuel management system you should beable to boost ~12psi safely. Although i might keep it to 8-10psi around on the street for safety.
Also check your compression before you do anything and make sure each cyl is within 5% of each other.
Last note, fuel management is the key...do the fuel right and you will have a very fun little car.
liam
Old 08-10-2001, 04:01 AM
sohc_boy's Avatar
if u keep boost below 10 psi, the car should be fine. u should also change your plugs to a couple of heat ranges colder and retard your timing a little. u should also make sure your fuel is ok, not lean rich is safe, as was mentioned before this is pretty importanant to the life of your motor. i would probably upgrade the ignition system too, although i ran my car w/ a turbo and stock ignition for awhile.
Old 08-10-2001, 07:28 AM
bigTom's Avatar
Default Re: Turbo for Civic!! (sohc_boy)
U DONT NEED TO LOWER YOUR DAMN COMPRESSION! i keep saying this yet people still think u need to lower it... honda's stock compression is fine with turbo... just make sure your fuel setup/management is setup right... imo it would be a waste to take off the head and put a new gasket on to lower the compression that little bit
Old 08-10-2001, 11:20 AM
DragII's Avatar
Default Re: Turbo for Civic!! (ek9t)
8-10psi for over 15k miles, and over a year, NO PROBLEMS WHAT SO EVER
as long as you pay attention to your car, ie a/f ratio, and don't boost it at every light, you'll be just fine
BTW I am running, stock compression, timing, and injectors
Old 08-10-2001, 11:23 AM
liam821's Avatar
Default Re: Turbo for Civic!! (PapaVTEC)
i soo agree with keeping the compression stock...But a lower compression is *safer* when problems arise...like if blow a vacuum line at 17psi (oops).
And with a honda running on pump gas with crappy hack ecu mods and other hacks to make it all work..sometimes safe is good.
liam
Old 08-10-2001, 11:24 AM
DragII's Avatar
Default Re: Turbo for Civic!! (liam821)
just to add, get spark plugs two ranges colder, and always run the highest octane gas available at the pump
Swifty
03-08-2005 02:21 PM
DualKnuttz
03-14-2003 06:52 AM
lazycoEX
03-10-2003 03:04 PM
Charles B.
10-29-2001 09:26 AM
Quick Reply: Turbo for Civic!!
