tune up for d16z6????
Old 09-08-2008, 06:59 PM
vinceiscoo's Avatar
Default tune up for d16z6????
i got a 1995 civic ex d16z6
i did oil, tranny flush, coolant flush, fuel injector cleaner, air filter, and got timing belt, alternator belt, power steering belt,and water pump, and also got cams seal
what else should i do?
i have about 160k mile
Old 10-25-2008, 12:37 PM
x2fast2belegalx's Avatar
Default Re: tune up for d16z6???? (vinceiscoo)
replace your plugs and wires, distrubutor cap, check all lines and hoses. possibly a clutch if a manual tranny.
Old 10-25-2008, 04:05 PM
trickytron's Avatar
Don't forget to check all of the steering and suspension components for wear and tear. CV boot rips, tie rods ends, ball joints, and rear trailing arm bushings. These things eventually wear out.
Old 10-25-2008, 04:09 PM
CodyC142's Avatar
Default Re: tune up for d16z6???? (trickytron)
I would also look into a new coil for the dizzy, these are known to crap out on hondas. Better safe than sorry
Old 10-27-2008, 06:39 AM
ej6hatchie's Avatar
bump
Old 10-27-2008, 07:07 AM
TravisCadello's Avatar
Default Re: tune up for d16z6???? (ej6hatchie)
Dizzy Cap And Rotor, Plug Wires,PLugs, And dont forget the dam fuel filter!. possibly new 02 sensor.
Old 10-27-2008, 07:34 AM
macson's Avatar
Default Re: tune up for d16z6???? (TravisCadello)
Also take a look to make sure your brakes aren't getting too worn down, you could bleed and change the brake fluid too if you're up for that. Not too much of a reason too though unless you have some problems or it's been a long time since.
If it's starting to get real cool outside in your area you can take a look to make sure your battery is good too. Just to make sure nothing's overlooked.
d1honda
25
07-01-2007 11:13 AM
RNPoo7
08-21-2005 02:05 PM
Ms.JDMdb8
07-09-2005 06:34 AM
Seks
08-09-2004 12:55 PM
IntEGNYC
12-05-2002 09:16 AM
Quick Reply: tune up for d16z6????
