TSC Sensor. Honda Guru's help needed!
TDC Sensor. Honda Guru's help needed!
Guys, I asked about the TDC (Top Dead Center) sensor before and got an explaination about it, but that was it and the thread was locked before I had a chance to ask anything else. I was curious if I can use a Used TDC sensor from say an autowreckers? I realize I run the risk of it not working and all that crap, but the stealership wants mucho dinero for it and I'm not made of money. Also I read somewhere you can't use used O2 sensors, so I figured it was the same as a TDC?
Thanks in advance for all the help!
ps - I run a 97 civic Hx (Yeahh VTEC-E )
Edit: Can a mod change the title to TDC, please?
Re: TDC Sensor. Honda Guru's help needed! (SlowHX)
TDC sensor is in the distributor, not easy to replace at all.
Replacing the entire distributor is usually the result.
make sure your wiring isn't the reason for the code before spending the money.
used O2 sensors are ok but chances are they will not last long. Beware your HX uses a unique 5-wire O2 that is hard to find. So be careful if you're shopping for an O2.
Dybowski
01-19-2009 02:49 PM
Eric S.
11
10-25-2004 08:14 PM
