tried tech forum.. nobody responds. well 1 did big whoop!
Old 04-11-2006, 10:50 PM
Out of every
Default tried tech forum.. nobody responds. well 1 did big whoop!
okay i took off my valve cover and my cam caps to get to my cam seal. i did this without purchasing a torque wrench forceing myself to buy one now. im going to sears tomorrow to purchase one.. what do i need in a torque wrench. 3/8 torque wrench or a 1/2? and how much foot pounds do i really need(for future projects). i dont want to spend over 150 for one. craftsman has one for 65.00$ 1/2 inch with 20 to 150 foot pounds. help me out
thanks in advance
Old 04-11-2006, 10:52 PM
CBEengineering's Avatar
Default Re: tried tech forum.. nobody responds. well 1 did big whoop! (e gee two)
if you have future projects i would buy the largest wrench you can find with the broadest spec then buy smaller ones later just make sure it fits the spec you are using now
Old 04-11-2006, 10:57 PM
Out of every
Default Re: tried tech forum.. nobody responds. well 1 did big whoop! (CBEengineering)
no one else reply! i got lazy its better to search
thanks anyway
ccjustin's Avatar
I don't think there's anything on a civic that's going to need moe than 100lb/ft. I have a snap-on 20-100 its awesome. the only catch is that a lot of stuff is like 14lb /ft or around that. go with 20-100, I have this one
http://buy1.snapon.com/catalog...talog
its easy to use, just remember to bring it all the way down past the lowest number when you're done using it
Old 04-11-2006, 10:59 PM
Out of every
Default Re: (ccjustin)
fine fine keep it coming. im sure alot of people would like to know this
Old 04-11-2006, 11:02 PM
Out of every
Default Re: (e gee two)
230 is alot i think i might just stick with craftsman. cheaper and lifetime warrenty thanks anyway
Old 04-11-2006, 11:14 PM
Squelch's Avatar
harbor freight?
Old 04-11-2006, 11:26 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccjustin &raquo;</TD></TR><TR><TD CLASS="quote">I don't think there's anything on a civic that's going to need moe than 100lb/ft. </TD></TR></TABLE>
What about crank pully bolts, or axle nuts? Those are looking at 135lbs.
It really depends on what your really going to do. If your going to be changing tires/rims often (like if you were at the track) then go with the 1/2 inch one for that. If its just little **** here and there then just get the 3/8ths. I have both and there great.
Old 04-12-2006, 12:05 AM
Out of every
Default Re: (Luserkid)
well i found what i was lookin for
search is my friend
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">Go to sears and get craftsman part numbers 44596/44597. It will cost about $190 plus tax.
IMO these are the best. The red box is for storage. It's sold seperately and can only be purchased online from sears.
The 3/8" wrench is adjustable in .5 lb increments from 5-80 ft.lbs.
The 1/2" wrench is adjustable in 2 lb increments from 25-250 ft.lbs.
Also displays newton-meters. The best display ever.
The tightest bolt on a honda is the axle nut (134 ft.lbs).
The difference is the amount of torque they can handle before breaking. I snapped a 3/8" breaker bar trying to remove an axle nut once. The axle nut was no match for my 1/2 drive breaker bar.
Modified by eda6 at 1:42 PM 12/19/2004</TD></TR></TABLE>
price has changed though i think 210 plus tax now
Old 04-12-2006, 12:32 AM
nello a.'s Avatar
i have the 1/2 craftsman. it worries me that the end of it is plastic. i posted on another one i had awhile back(cant remember where i got it). anyway, took car to a friends shop after installing aspec with 22mm sway and found out that the wrench was off by 7 ft.lbs(not the craftsman). he had the digital snap-on. it beeps and vibrates.
Old 04-12-2006, 12:38 AM
fmrprojects's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccjustin &raquo;</TD></TR><TR><TD CLASS="quote">I don't think there's anything on a civic that's going to need moe than 100lb/ft. I have a snap-on 20-100 its awesome. the only catch is that a lot of stuff is like 14lb /ft or around that. go with 20-100, I have this one
its easy to use, just remember to bring it all the way down past the lowest number when you're done using it</TD></TR></TABLE>
yes there is, the crankshaft bolt 130 ft lbs
Out of every "game"
04-14-2006 05:42 AM
drudy
01-31-2005 03:03 PM
92 GSR
07-17-2003 12:56 AM
216.226.142.95:27016
06-05-2003 05:55 PM
InfamousRS
06-02-2002 09:02 PM
Quick Reply: tried tech forum.. nobody responds. well 1 did big whoop!
