Transmission problems.[HALP]
Recently I changed the driver side CV joint and axle in my EG. Everything went smoothly, except when i went to go drive it. When i put the car into gear I get nothing (manual transmission). At Idle with no gas applied, when i shift into 1st, my Speedo reads 20mph but im still standing still. As i go up through the gears the speedo also rises. I checked fluid levels in my transmission as well as clutch fluid...both are topped off. the axle seems to be seated into place inside of the transmission as well. Now I am clueless as to what is wrong. Any input is much appreciated.
Re: Transmission problems.[HALP] (sloweg1994)
It sounds like you don't have the cv seated all the way into the trans. there should be no gap between the trans case and the cv shaft.
Tyler Atwood
07-02-2019 04:40 AM
