Trans questions
Trans questions
Anybody know whats the diff between a s20 and a s40 5 speed trans someone told me years 92-95 and 96-98 im askin cause i got a 98 civic ex with trans trouble and someone said i can use the s20 trans he gave me......ANY HELP WILL DO?????......ANY PROBLEMS,CONCERNS,WARNINGS???????? PLEEEEEASE HELP I AINT GOT REVERSE
Re: Trans questions (DysturbinDaPeace)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DysturbinDaPeace »</TD></TR><TR><TD CLASS="quote">Anybody know whats the diff between a s20 and a s40 5 speed trans someone told me years 92-95 and 96-98 im askin cause i got a 98 civic ex with trans trouble and someone said i can use the s20 trans he gave me......ANY HELP WILL DO?????......ANY PROBLEMS,CONCERNS,WARNINGS???????? PLEEEEEASE HELP I AINT GOT REVERSE</TD></TR></TABLE>
SEARCH up noob...you would have found that S20 has shorter gears then S40...now go search for more info..
Re: Trans questions (B18CivicEg)
ive been trying to search!!!!!! so your answer is yes it will fit no problems????just shorter gears right? Im gonna need better search resources.... any suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DysturbinDaPeace »</TD></TR><TR><TD CLASS="quote">look peeps im just looking for advice to put this s20 trans in or not</TD></TR></TABLE>
yes...you can use it...
S20 transmission is from 92-95 Civics
S40 transmission is from 96-00 Civics
S20 will fit on 96-00 Civics and vice versa. There is minimal difference in gear ratios between the S20 and S40 EX transmissions; mian difference is steel shift forks in the 96-00 transmissions.
