Tranny won't come out...
every bolt is off but the tranny won't slide out. i don't have a tranny jack and the motor is sitting on a jack. any help? https://honda-tech.com/forums/images...es/emsmile.gif
Re: Tranny won't come out... (Unjockable)
did u take the starter off those are tranny bolts to. pry it and it will come right off
Not sure, but good luck to ya
Re: Tranny won't come out... (95blkgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95blkgsr »</TD></TR><TR><TD CLASS="quote">did u take the starter off those are tranny bolts to. pry it and it will come right off</TD></TR></TABLE>
yeah, i got the starter off already. |
double check for any other bolts and if u got them all pry it off with a crowbar should come right off
crobar is ur friend...
Re: Tranny won't come out... (PRcivicHB)
yeah, i'm positive there's no other bolts. i'll try using a crowbar but don't want to make any marks on the tranny.
ya this shit is kinda dificult some times you just gota pry with equal force to opposing sides
Re: Tranny won't come out... (slammed_93_hatch)
aite...thanks for the tips.
I had the same problem, but it was because my dumb self forgot to take of the flywheel shield.
make sure you have the flywheel cover bolts out. a few 10mm bolts right next to the oil pan. do 1 final check to make sure u got all the other bolts out.
Re: Tranny won't come out... (Downey)
yeah, flywheel cover is out. tranny still won't come off... http://images.honda-tech.com/set1//smile/emcrook.gif
there may be one more 17mm or 19mm bolt on the rear side. There are the 2x19mms that go to the rear T bracket and there is one more back there... might be hard to see.
Re: Tranny won't come out... (EG2 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR »</TD></TR><TR><TD CLASS="quote">there may be one more 17mm or 19mm bolt on the rear side. There are the 2x19mms that go to the rear T bracket and there is one more back there... might be hard to see.</TD></TR></TABLE>
yeah, i got those. https://honda-tech.com/forums/images...es/emsmile.gif |
Is it an auto trans?
is this b series.....also remove the intermediate shaft
If you have all the bolts out, the starter, and the flywheel shield then your solution is simple, either A- pry on it a little bit. or B- pull harder. Sometimes the guides are pretty tight into the tranny and prying will be the only way off.
[QUOTE=Unjockable]yeah, i'm positive there's no other bolts. i'll try using a crowbar but don't want to make any marks on the tranny. [/QUOTE=UNJOCKABLE]
why not? its not like you see ur tranny every day. unless ur under it fixing it every day, like mine. https://honda-tech.com/forums/images...s/emsmilep.gif |
Re: Tranny won't come out... (97civhatch)
just got it out. i started seeing a crack. https://honda-tech.com/forums/images...es/emsmile.gif
oh, that cant be good. http://images.honda-tech.com/set1//smile/emcrook.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civhatch »</TD></TR><TR><TD CLASS="quote">oh, that cant be good. http://images.honda-tech.com/set1//smile/emcrook.gif </TD></TR></TABLE>
maybe he meant a crack from where it was seperating from the motor |
