tranny swaps....
Re: tranny swaps.... (5thgen)
Definelty possible. I don't know the gear ratios off the top of my hand but I'm assuming the reason you want to do this is because the ex tranny has closer gears then the dx so you'd want the dx for a turbo, similiar to a turbo b-series using the ls tranny because the gearing is spaced further apart. If you are lucking to attempt this it's a straight forward swap.
Brian
[Modified by VtecDeMoN, 5:44 AM 5/29/2002]
Brian
Re: tranny swaps.... (VtecDeMoN)
92-95 ex
1st: 3.25
2nd: 1.9
3rd: 1.25
4th: 0.909
5th: 0.702
6th (if availble): 0
Reverse: 0
Final Drive: 4.25
97 dx
1st: 3.25
2nd: 1.761
3rd: 1.066
4th: 0.852
5th: 0.702
Reverse: 0
Final Drive: 3.25
thats from hondaswap....don't know if its accurate. I'm just asking because I have a 97ish dx tranny and axles sitting around.
1st: 3.25
2nd: 1.9
3rd: 1.25
4th: 0.909
5th: 0.702
Reverse: 0
Final Drive: 4.25
97 dx
1st: 3.25
2nd: 1.761
3rd: 1.066
4th: 0.852
5th: 0.702
Reverse: 0
Final Drive: 3.25
Re: tranny swaps.... (buster13)
If you're swapping it to an EX engine the gears will top out once you hit the rev limiter with the EX engine, 7200RPM. Changing gearing doesn't affect the redline, just how fast you get there.
Re: tranny swaps.... (SpecR_EK)
I know they'll top out at whatever redline the motor has...I was just asking him what it topped out on the dx motor (6800?) so I could sort of compare with the 94 ex (7200).
D Tranny Guru
Re: tranny swaps.... (TurboD16Z6)
how is it not as strong when they use the same parts?????
PLEASE explain this.
[Modified by Mista Bone, 6:34 PM 5/29/2002]
Re: tranny swaps.... (Mista Bone)
I have no experience with this but a few of my friends have busted cx and dx differentials but never an ex. I have a quaife in mines so it's not a problem. That's just my experience with this.
D Tranny Guru
helped put a 93 EX tranny in a 96 DX HB, he dropped over 1/2 second at the track.
Trust me you want the EX/Si gearing. NOS boosts torque way more than turbo. I ran 13.09 with stock gearing and top speed (if you desire) was over 140 mph.
Just a D motor.
Just a D motor.
Joey Mitchell
04-29-2019 07:50 AM
EK45VTi
16
10-31-2004 03:05 AM
Unjockable
10
12-12-2001 04:21 PM
