Tranny removal
Old 06-07-2002, 11:52 AM
Tyson's Avatar
Default Tranny removal
Swapping the clutch and got a quick question, how do you best separate and lower the tranny from the engine? i got most the three mounts off the tranny and i think all of the bolts. im havinga bit of trouble completley separating the tranny, worried about damaging the input shaft. engine is on a EG Si A6.
Old 06-07-2002, 11:56 AM
.nate's Avatar
Default Re: Tranny removal (Tyson)
Work it back and forth.. shake that ho! get it enough so you can get the blade of a screwdriver in it and work it apart that way
Old 06-07-2002, 12:03 PM
94CivicSi's Avatar
Default Re: Tranny removal (TheFLY)
Yah, there are 2 guide pins between the block and bell housing. Mine were kinda sticky too. I used a small crow bar and just pryed a little bit on each side. Work on side, then the other, repeat. You do want to be careful with the input shaft so take your time.
Old 06-07-2002, 12:13 PM
Tyson's Avatar
Default Re: Tranny removal (94CivicSi)
thanks guys, gonna try again, will probably get it done. just needed the boost.
Acrappyhatch
05-12-2006 08:27 AM
stRtypR25
12-20-2002 01:35 PM
spladam02
12-09-2002 06:05 AM
hybridcrx
02-28-2002 04:38 PM
Scooby
02-22-2002 06:09 PM
Quick Reply: Tranny removal
