tranny question with problem
I have a 2nd gen b16 in my eg. On the tranny, just above the lower motor mount there is a little crack. But the car runs and drives fine. Is this a problem?
Thanks
Thanks
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
Re: tranny question with problem (gsrhb7)
crack where the front 17mm's go or else where above that on the gear casing? as long as it's not leaking shouldn't be a problem. if it's cracked where the bolts go as long as you have two others i suppose it's better than nothing.
