tranny question
tranny question
i have a stock d16y7 in my 97 dx, and i was wondering if i could swap in a z6 or equivalent trans. is it the same to mount/run for all hydro trans?? im in dire need of a new trans, and one came up... need to know if will fit or not (also if a 95 clutch would work..?) thanks much!
Re: tranny question (crazykamper)
for your y7 motor any d-series from 92-2000 tranny will bolt right up, so the z6 tranny will fit and its better than your y7 tranny.
is it a direct swap? would i need anythin else to run it etc? also, will the clutch work from a 95 civic into my 97?? (entire clutch kit : pressure plate throwout etc...) thanks much!
Seagull Management
Yes, it'll work, clutch is the same, tranny is the same. completely interchangeable.
Edit, by tranny is the same i mean it bolts up the same, Z6 is geared better, but completely interchangeable, just wanted to clarify.
Modified by 94EG8 at 10:21 AM 7/29/2008
