tranny leaking form axel!!! ALOT!
so i get my new DSS stage one axels for my H22A EG swap and the on the passenger side of the tranny ther is a huge leak from the axel hole thingy!
i have replaced the both seals there and it was fine then all the suddan it was just pooring out!
i was able to move the axel in maby a CM but it continued to leak but not as much.
i can also get under there and move the cup in and out. am i supposta to be able to do this?
could it be a manufacture defect?
thx all!
and here is a pic to lure you all in muahhhahahahaha!
thx all!
As long as I dont have to take out any more Metal Gears
Re: tranny leaking form axel!!! ALOT! (H22A EG6)
there should be no gap between the seal and the axel, and the axel should have very little play if any. If u can move the axel 1cm, then u have got to do something about that
Re: tranny leaking form axel!!! ALOT! (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one »</TD></TR><TR><TD CLASS="quote">there should be no gap between the seal and the axel, and the axel should have very little play if any. If u can move the axel 1cm, then u have got to do something about that </TD></TR></TABLE>
LOL i know i got to do sumtin about it!
do you think it is the axels or the diff or the seals
when in doubt, change it anyways, better to change it while u can rather than finding out later u should have changed it and have to take everything apart again. well u should change the seals, the axel is supposed to be right up against it creating a "seal" if the axels arent in all they way, it could damage the diff or the axel, or both. hopefully they are not
sounds like the clip on the axle came off. you should only be able to move the axle a cm or two. and the leaking could be a seal
Sounds like the snap rings are sized too small. It happend to me too.
Buy some OEM ones and use those...fixed mine right up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 »</TD></TR><TR><TD CLASS="quote">and here is a pic to lure you all in muahhhahahahaha!
your lure got me =[
your lure got me =[
Re: tranny leaking form axel!!! ALOT! (Syner-G-Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing »</TD></TR><TR><TD CLASS="quote">sounds like the clip on the axle came off. you should only be able to move the axle a cm or two. and the leaking could be a seal</TD></TR></TABLE>
that is exactly what i thought i will take em out and look em over later i got to move into my dorm no car and no girl friend
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIYaccord »</TD></TR><TR><TD CLASS="quote">Sounds like the snap rings are sized too small. It happend to me too.
Buy some OEM ones and use those...fixed mine right up </TD></TR></TABLE>
lol repace my $400 drive shaft shop axels with oem ones
but your snap rings thins sound right on like Syner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazynok »</TD></TR><TR><TD CLASS="quote">
your lure got me =[</TD></TR></TABLE>
LMFAO
LMFAO
as i said in my first post!
LMFAO </TD></TR></TABLE>
I feel you man. I went through hasport for my driveshaft shop axles for my B18C-R / 5th gen civic set up. Its easy for them to put the wrong snap rings on the shaft.
Do they lock in at all...snap...crackle...or pop? (kinda makes you hungry huh? )
nope no snap crackle or pop
i am gonna call them in a couple of days i am gonna be busy as hell
thx guys!
i will keep you updated
thx guys!
but your snap rings thins sound right on like Syner</TD></TR></TABLE>
lol, NO...
Buy some oem SNAP RINGS not the whole axle
lol, NO...
Re: tranny leaking form axel!!! ALOT! (DIYaccord)
yea i bet that is cheaper then sending em back will do
H-T is the ****!
H-T is the ****!
Re: tranny leaking form axel!!! ALOT! (Vtecin94dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecin94dx »</TD></TR><TR><TD CLASS="quote">sounds like the seal is fucked up... i dunno</TD></TR></TABLE>
if u can move it in and out then yer missing the clip/snap ring that holds the axle in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_Em1 »</TD></TR><TR><TD CLASS="quote">
if u can move it in and out then yer missing the clip/snap ring that holds the axle in </TD></TR></TABLE>
Thats what I said!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 »</TD></TR><TR><TD CLASS="quote">yea i bet that is cheaper then sending em back will do </TD></TR></TABLE>
Yeah it is...$5 get's ya two brand new OEM ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 »</TD></TR><TR><TD CLASS="quote">H-T is the ****!</TD></TR></TABLE>
Best Site EVAA!!! I <3 Honda-Tech!
Thats what I said!
w3rd
w3rd
w3rd</TD></TR></TABLE>
Re: tranny leaking form axel!!! ALOT! (Slow_Em1)
so i pulled the axle out there is aring on the end but when i get it in all the way it still pulls out with ease.
anyways i ordered new ring from honda i will try that if it does not work i will be on the phone with DSS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 »</TD></TR><TR><TD CLASS="quote">so i pulled the axle out there is aring on the end but when i get it in all the way it still pulls out with ease.
anyways i ordered new ring from honda i will try that if it does not work i will be on the phone with DSS </TD></TR></TABLE>
Betcha that was it!
Betcha that was it!
yoimbobdole
10-13-2004 01:06 PM
