Tranny Fluid Pouring Out
Well I was driving and I felt a thud (even in my shifter) but didn't hit anything. In the next minute it was really hard to shift to any gears. I pulled over and a stream of oil was coming from under the car. I was about a minute from home so I took it and parked it. By this time the fluid had stopped leaking out, it was all over so I couldn't figure out where it was coming from. I poured some oil in the tranny and it came right out the little hole in the flywheel cover. Also I just had the clutch changed 2 days earlier. Has anyone ever had this problem or has an idea of what it could be?
Re: Tranny Fluid Pouring Out
one of a few things could have happened. my best guess would be that your clutch pressure plate broke, and smashed into the diff casing. causing it to break or put a hole on the inside of the bell housing.
hate to say it but you're going to have to take off the tranny and look.
no problem. just dont freak out to much when you see that hole in the tranny. just be calm and dont go crazy (like i did when i blow a hole in my tranny) good luck
