tranny?
tranny?
how much does it cost to get a tranny fix. i think my gear are grind up so just wanted an estimation. or should i get a new one.
edit b16 tranny
edit b16 tranny
Risky Business
Re: (jdmrac3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrac3r »</TD></TR><TR><TD CLASS="quote">it goes into gear but i can't punch it any higher then 20mph.</TD></TR></TABLE>
Can you be any more specific at all?
Re: (BauleyCivic)
well when i push on the gas when im on first it goes no fater then 20mph and if i try to go any faster it kind of lag a bit can't really explain it.
Risky Business
Re: (jdmrac3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrac3r »</TD></TR><TR><TD CLASS="quote">well when i push on the gas when im on first it goes no fater then 20mph and if i try to go any faster it kind of lag a bit can't really explain it.</TD></TR></TABLE>
Sounds like an engine problem...
Re: (jdmrac3r)
is it only in first gear? what happens with various throttle positions?
trouble shooting this problem with your wonderful description is like ******* a dead horse. please be as detailed as you possibly can. what car / motor / tranny etc etc. first you said you think 'my gear are grind up' and then it won't go higher than 20 in first, and now it just bogs out after 20. come on.. there's a lot of smart people on this board, but none of them can read your mind over the internet.
again: i can't help you with such a vauge description. if you want help, i need you to be as absolutely descriptive as possible. post every little detail. a lot more than 'can't punch it after 20'. be very specific: what happens, when it happens, very very specific, any thing unusual, any noises, anytime it doesn't happen etc etc etc. if you don't have the brain capacity to do that good luck.
Re: (jdmrac3r)
in first yeah a 2000 si will be in the 35 mph range at red line.
i highly doubt it has anything to do with your tranny if it just cuts out or bogs at 20mph. it has to be something related to the motor. please dont ask me what is wrong unless you give something to help diagnose.
Re: (GERM)
check fluid..u may have the wrong kind of fluid in there..stick with the recommend d OEM fluid s..too many try a too slippery fluid and the syncro s wont engage
its not recommend d a syn fluid be used..its better to use a straight 30w oil
Re: tranny? (GERM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GERM »</TD></TR><TR><TD CLASS="quote">all depends on whats wrong with it. labor is what is expensive. the parts wont be too bad if its just syncros.
agreed... sometimes it will cost u less to buy a new tranny and sometimes its worth fixing it.... a tranny mechanic told me once "we wont know **** until we actually open the tranny"... so its anyones guess
Re: tranny? (H22A EG6)
With the (lack of) explination, I'm going to just say learn to drive and give us more detail. H22A EG6: Congrats on hitting the 666 posts mark!
