Trailing arm question
Re: Trailing arm question
ther is no front trailing arm, on civics, only rear trailing arms. assuming you are looking for the lower control arm for the front of your 94 LX, you can use any LCA from any model civic 92-95. no for the hub, i belive you have to pull something from a civic that has abs. why do you need new ones in the first place?
I suppose it is the LCA. The thing that has the hub attached to it... anyway, I dont have a 12ton press I can use to remove my hub and apparently it would be cheaper just to get a new assembly than having a shop press out/ in my hub so I can change the studs.
MXHowes
Honda Civic (2001 - 2005)
01-16-2011 07:17 AM
chrisw85
23
04-06-2009 09:03 PM
