TPS wires....any help?
Ok, so here is the deal. This project has nothing to do with a honda, but since I am familiar with hondas I have decided to use a honda TPS on my current project.
I am using the TPS on a carbureted engine via a bracket that I fabricated to mount the civic TPS to my edelbrock carburetor.
I know the TPS runs .5 volts to volts at WOT. My question for the smart folks is....
What wire gets the constant voltage? And IIRC there are 3 wires on the TPS?? where do they go and what is their purpose?
Obviously I am not using an ECU...so I basically just need to know what wire I feed constant voltage to and what wire I use to get my variable reading.
Thanks guys!!!
Rob
Thanks guys!!!
Rob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">You need to connect a multimeter to the tps and move the sensor around until the correct ohm specs are achieved.
With the TB closed, sensor disconnected, ign off:
Pins 1 and 2 = 0.5-0.9ohms
Pins 2 and 3 = 3.6-5.4ohms
You also need to be sure you have correct voltage, sensor connected, ign 'on':
Pins 1 and 3
0.5volts with the TB closed
4.5volts with the TB fully open</TD></TR></TABLE>
Based on that, Id say the 1st pin is the voltage, 2 is signal, 3 is ground.
Pins 1 and 3
z6hatchboy
02-03-2008 07:42 AM
drjondurst
21
04-09-2003 08:37 PM
