TPS problems??
TPS problems??
What is the easiest way to tell if my TPS is not working properly?? NEED HELP FAST
Re: TPS problems??
at least your shut off, mine doesn't do any difference even when i unplug it or take it out of the TB. which i dont even know what to do now.
Re: TPS problems??
sorry im not trying to steal this thread but im able to rev past 3 rpm and drive all the way to 8k with np without my tps being hook up. so im going to replace the ecu and after that i'll be clueless.
Re: TPS problems??
Use a volt meter and measure the resistance comming out of the middle wire. 1 Wire should have 5v one is a ground. I think fulled closed you should be getting 0ohm of resistance and fully open around 4.5. Or i have that backwords.
Re: TPS problems??
You're on the right track but you measure voltage coming out not ohms. So hook the ground side of the meter to a known good ground (ex. battery negative since its fairly close) and the red lead to the red with blue tracer wire (assuming its and eg style civic) on the TPS connector. Closed should read 0V- about.5V, and WOT it should be about 4.5V- 5V.
Re: TPS problems??
its not hard to check the voltage coming from the tps. i put in new one yesterday and set it at .45 at close throttle and i get 4.78 at full throttle, but still have the check engine light for it. im clueless now.
Re: TPS problems??
Its not get a T Pin or a sewing needle and push it through the back of the connector
Re: TPS problems??
My idle dont jump around or no cel's r on mine...it jus doesnt wanna start somtimes wen it jus up to temp???im thinking is the fuel pressure reg??
