too too dark
too too dark
whats the easiest, most cost effective way to <U>remove</U> proffesional tints from windows?
95' dark blue dx hatch with dark tints looks like ***
New User
Re: too too dark (VTiHatch)
Wet the tint, place a BLACK plastic garbage bag over the window, put defrost on high heat and leave car running for 35 minutes - 1 hour. It will peel right off with no residue.
Re: too too dark (POS Hatchback)
on a sunny day, place tin foil on the inside of ur windows. Wait as long as desired, prolly at least an hour or two, then go out and proceed to peel. This seems to work the best.
Chris
Chris
Re: too too dark (976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 »</TD></TR><TR><TD CLASS="quote">Wet the tint, place a BLACK plastic garbage bag over the window, put defrost on high heat and leave car running for 35 minutes - 1 hour. It will peel right off with no residue. </TD></TR></TABLE>
interesting,..are you speaking from experience or what you have heard???
New User
Re: too too dark (blazinb16)
I don't want to explain the facts of why it works, however, I PROFESSIONALY installed window tint in my local area for all the basketball and footplayers, and other side jobs until I realized I had a brain, now I'm using it rather than installing tint.
If you do get left over glue, use simple green, it is the only thing that will biodegrate the glue so you can rub it off.
z6EJ1
11-15-2006 11:31 AM
Db1 Supreme
17
12-29-2003 06:31 PM
