tips on making inside car quieter
I'm looking for any help on where to look for products or whatever just need to know how to make the inside the car quieter.
The Grumpiest
Re: tips on making inside car quieter
Good luck with that. These cars are not known for their quiet interiors to start with. You can soundproof some but be prepared for a major project.
Google how to soundproof my car.
Sound deadening. Rammet(SP) is recommended by a few people I know.
Dynamat is great, but quite expensive.
Get ready for a major project. You'll need to gut the car.
No reason to buy Dynamat when you can get the exact same thing, minus the name brand, for a quarter the price at your local hardware store. How quiet you can make your car purely depends on how much work you're willing to put into it. Sound deadening material under the carpet and roof line is easy. Deadening foam in the door panels is a little harder, but gets you one step closer. Rubber o rings under every nut and bolt is the next step, and is a bit time intensive. Removing the engine to sound deaden the bay is the final step, with the most effort, and the greatest reward.
You can use Peel & Seal in place of Dynamat for a less expensive route. Can buy it at Lowe's or roofing supply stores in 4" or 6" width sizes.
thanks, i plan on doing a lil at a time eventually getting all done. its a 93 hatch so it must be done....its a daily driven, still in charlottesville? in staunton myself
Fill your quarter panels with polyfill and use dynamat or second skin deatner. There is a huge difference between peel n seal and dynamat. Dynamat the floor you will notice a huge difference.
Do I just buy some at Home Depot?
Ridin Dirty in Cali
Great tips! I had an "Ah-HA!" Moment when you mentioned the rubber O-rings under every bolt. Ever since I retrofitted GSR leathers into my Civic its created this annoying squeak. I've checked all the bolts and its snug and tight, but the rubber O-rings should do the trick.
You might be hearing that squeek and think its the seat mount bolts when it very well could be the seat back.
I have had some RSX seats make an annoying squeek and it turned out to be the back was a little loose.
Good call, and that may be the case. I'll check that too. Thanks for the tip!
http://www.sounddeadenershowdown.com/cgi-bin/index.cgi
Technical Hero
Whatever you do please document it with pictures and what did or didn't make a difference and make a write up to help others in the future with this question.
Here are some DIYs
http://www.clubcivic.com/board/showthread.php?t=59188
http://www.fitfreak.net/forums/2nd-g...lots-pics.html
Here are some DIYs
