Timing belt shaking... normal?
I just bought this car a week ago, and it didn't come with an upper timing cover... I was removing all the wiring for the system that used to be in it, and noticed the ecu wasnt secured in the process, so I bolted it back up and started the car to make sure i didn't loosen any wiring. I looked at the timing belt and noticed the belt will vibrate or shake during idle and vibrate even more when revving the motor. It's a b16a2. Just want to know if this is normal, or if I should slap a new belt and tensioner on it just to be safe?
Re: Timing belt shaking... normal?
No, that is not normal. Does the belt have excess play in it, or is the cam pulley wobbling? If its the belt, sounds like a new belt and tensioner would fix the problem.
With the engine off, the tensioned side has very little play, but the untensioned side has a bit too much i would think. I didnt notice any of the cam pulleys wobbling at all, they seem pretty sturdy... Anyone have a website to recommend for ordering oem parts?
