Timing Belt Replacement Trick
Old 03-11-2011, 07:38 PM
  #26
Seagull Management
94EG8's Avatar
Default Re: Timing Belt Replacement Trick
I get the theory here, but it seems like more trouble than it's worth. I imagine it's rather difficult to cut the belt that way.
The biggest mistake people make when doing timing belts is trying to take up the slack on the front side.
Old 03-12-2011, 08:33 AM
  #27
v8killaz's Avatar
and i cant cut the timing belts in half i use them to make my belt. seriosuly
Old 03-12-2011, 01:42 PM
  #28
#1 Super Guy
94eg!'s Avatar
I think it would take WAY more time to cut the belt down the middle (which sounds next to impossible BTW), than it would to simply line up all marks and slip a new belt on. Either way you still need to spin the motor around by hand afterward to double check all marks still line up.
Good effort though...
Old 03-12-2011, 05:02 PM
  #29
zdizzle's Avatar
cover,pulley,tentioner u did all the hard work all ready
Old 03-12-2011, 10:01 PM
  #30
darkcivic90's Avatar
LOL...FIR THING IF YOU REPLACE T-BELT YOU NEED TO REPLACE WATER PUMP AND TENSIONER IS YOUR TEACHER TOLD THAT TO YOU OR NOT??THIS POST IS MAKE SINCE BUT WHY WOULD I/YOU DO THAT IF I/YOU CAN DO IT THE RIGHT WAY AND EASIER AND NO CONFUSING....I CAN REPLACE T-BELT IN LESS THAN HOUR THAN WASTING TIME TO CUT THE BELT IN HALF...
Old 03-12-2011, 10:56 PM
  #31
Master Detailer
98civdx's Avatar
Turn the caps off, and learn to type in a manner that is read easily. Then, you can brag about how you can do a timing belt in 1 hour. Which for some reason I think you aren't telling the truth.
Old 03-12-2011, 11:26 PM
  #32
Wrona's Avatar
Nerd rage much? the kid was giving a suggestion on how you can do your timing belt jesus... dude go back to school or something because i had to reread what you said many times to actually understand it...
Old 03-12-2011, 11:37 PM
  #33
N/A
Purpose Built
N/A's Avatar
He is right tho, if your gonna do it, do it right. It is recommended to change the belt, pump, and tensioner all at once
Old 03-13-2011, 04:05 AM
  #34
whityeh2's Avatar
i just changed the t-belt on my car and cutting it seems to make it more difficult if u dont know what ur doing
Old 03-13-2011, 06:58 AM
  #35
fabioso's Avatar
x2 if you get that far then you'll be ok lining up the cams. ONe thing I love about hondas is they are easy to work on compared to my older corolla.
Old 03-13-2011, 07:23 AM
  #36
N/A
Purpose Built
N/A's Avatar
Do u guys not know honda makes pins to lock the cams in place?
Old 03-13-2011, 08:32 AM
  #37
NotAJDMFanBoy's Avatar
Is there a way to lock the crank at TDC? Is there pins for the SOHC heads? Or is that just for DOHC?
It's not hard to see that the cam is in the right position, but the crank is a little harder since the mark on the pulley is pretty faint and the mark on the oil pump is usually covered by dirt.
I guess a good tip for people would be to power wash or at least hose down their engine and engine bay after using degreaser on it. A clean engine is so much nicer to work on.
Old 03-13-2011, 09:25 AM
  #38
N/A
Purpose Built
N/A's Avatar
U s,houldn't have that much dirt in there,
Even if a lil carb cleaner will clear it up.
Old 03-13-2011, 09:49 AM
  #39
that_boy_sammy's Avatar
Haha nice man why didn't i think of that. Instead of cutting your belt in half and breaking it(like stretching a rubber band and breaking it) he cut it in half the other way like tearing a piece of string cheese from top to bottom. Now that the belt is cut that way he left the side thats closer to the motor on and took the other half off, put the new one and cut the last bit of the old one off.
Old 03-13-2011, 11:35 AM
  #40
TypeRMOBBiN209's Avatar
this is actually a good idea..im gonna try it next time! i can't do timing for ****
Old 03-13-2011, 11:38 AM
  #41
Master Detailer
98civdx's Avatar
No one siad he was wrong.
Any one with half a brain cell can search and figure that out.
Old 03-13-2011, 12:27 PM
  #42
Sure, that works. Either way, having it all clean would make it easier.
Old 03-14-2011, 01:18 AM
  #43
N/A
Purpose Built
N/A's Avatar
Then y u guys giving him ****?? All over some capital letters? Lol
Old 03-14-2011, 12:02 PM
  #44
Master Detailer
98civdx's Avatar
He can't even freaking spell! if you want to be taking serous learn spell, and type like someone who has half a damn brain cell.
Another reason is, timing belt in a hour?
The caps doesn't really bug me, it's the fact it took me 3 try's just to guess what he is trying to say.
Old 03-16-2011, 03:44 PM
  #45
Robert2011's Avatar
Thanks for the post! I'm no rocket scientist, but it made since to me. I'm going to give it a try.
Old 02-10-2013, 07:21 AM
  #46
DaveMarx's Avatar
I couldnt help but join the forum after reading this. Good idea.. but so overly time consuming. Clamps. Just use clamps. It's far too easy a job to go through all this... and you should change the pump and rollers... always.
Old 02-10-2013, 09:51 AM
  #47
hwyix's Avatar
I prefer to mark the old belt (crank, cams). Count how many teeth then mark the new belt. That is how toyota does it.
Comp97GSR
12-30-2022 12:10 PM
dleccord
04-13-2020 08:03 AM
airikkCRX
04-02-2010 08:29 AM
civic=goodgasmileage
Honda Civic (2001 - 2005)
10-11-2008 09:17 AM
MassCivicMan987
06-28-2007 11:48 AM
Quick Reply: Timing Belt Replacement Trick
