timing belt
Old 10-20-2003, 11:41 AM
JSPECEX's Avatar
Default timing belt
i did a timing belt on a 91 accord and i lined everything up dead on followed every procedure for tensioning it and it wont hold tension. i took it off and tried again nothing. does anybody have any suggestions. thanks for the help
Old 10-20-2003, 12:40 PM
Jmunk's Avatar
I usually put it on and spin the crank half a turn or so (counter clockwise) than i tighten up the tensioner. Try that, how much slack is there in the belt ?
Old 10-20-2003, 12:47 PM
civic_tuned's Avatar
Default Re: timing belt (JSPECEX)
Get a new tensioner
Old 10-20-2003, 01:39 PM
jolt-tsp's Avatar
Default Re: timing belt (civic_type_r)
Might wanna post in the accord forum, just in case they require some step we civicers don't need to worry about on our engines.
Old 10-20-2003, 03:55 PM
JSPECEX's Avatar
Default Re: timing belt (jolt-tsp)
yeah i thought that but i have a civic and i always post here and you guys respond way faster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp &raquo;</TD></TR><TR><TD CLASS="quote">Might wanna post in the accord forum, just in case they require some step we civicers don't need to worry about on our engines.</TD></TR></TABLE>
Old 10-20-2003, 03:56 PM
JSPECEX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_type_r &raquo;</TD></TR><TR><TD CLASS="quote">Get a new tensioner</TD></TR></TABLE>
that is what i was thinking but do you guys know of anyways of testing it
Old 10-20-2003, 03:58 PM
DumpedSi's Avatar
Default Re: (Jmunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmunk &raquo;</TD></TR><TR><TD CLASS="quote">I usually put it on and spin the crank half a turn or so (counter clockwise) than i tighten up the tensioner. Try that, how much slack is there in the belt ?</TD></TR></TABLE>
Old 10-20-2003, 04:12 PM
JSPECEX's Avatar
Default Re: (Jmunk)
i already have done that everytime
Old 10-20-2003, 06:14 PM
tangb2023
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECEX &raquo;</TD></TR><TR><TD CLASS="quote">
that is what i was thinking but do you guys know of anyways of testing it</TD></TR></TABLE>
check it by.. when it is not tightning up... get a tensioner.. if it does the same thing then return.. pretty sure it is the tensioner though.. accords have 2 timming belts.. are there 2 tensioners???
Old 10-20-2003, 06:18 PM
JDM-97CX's Avatar
Default Re: timing belt (tangb2023)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tangb2023 &raquo;</TD></TR><TR><TD CLASS="quote">
accords have 2 timming belts.. are there 2 tensioners???</TD></TR></TABLE>
huh? are you sure about that? cuz i dont see how having two timing belts would work on that motor.
Old 10-20-2003, 06:50 PM
pro1342's Avatar
Sometimes you have to push up on the tensioner a little to get the right tension, just be sure you don't get the balance belt too tight.
Old 10-21-2003, 08:16 AM
JSPECEX's Avatar
Default Re: timing belt (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">
huh? are you sure about that? cuz i dont see how having two timing belts would work on that motor.</TD></TR></TABLE>
there is a tensioner and a balancing belt. how do i know if the balancing belt is to tight. so you guys think it is the tensioner to. it is not my car just a side job so i will have them pick both up and i will see what happens. this is making me wonder becuase when i took off the lower cover there was no spring on the balancing belt tensioner, so maybe that is were the problem is. i replaced both springs. also both his belts didn't look in that bad of shape
Old 10-21-2003, 08:25 AM
JDM-97CX's Avatar
oh yea i forgot about the balancing belt, i guess i just misunderstood because i was trying to fgure out why it would have two timing belts
88CRX-CRB-UT
09-14-2007 09:29 PM
Luder_Civic
07-24-2006 02:35 PM
IowaHonda563
09-17-2005 08:52 PM
EL Vap133
04-26-2005 11:32 PM
1998hondaaccord
08-12-2004 12:59 PM
Quick Reply: timing belt
