Time it takes to do a mini-me swap
Re: Time it takes to do a mini-me swap (bmw626)
I did my mini me at a buddies garage with all the tools needed. Took us about 5 hrs, but we ran into a few snags here and there. Didn't get the knock sensor wired in because I didn't have one and had to drive the car to work late in limp mode
Re: Time it takes to do a mini-me swap (chowmien)
I know its too late to ask since all my parts are being shipped to me right now, but was the swap worth it for the extra 25HP and VTEC?
The swap will help, but the two biggest helpers to get you from a DX platform to an EX level is the intake manifold and the EX tranny. Get those 2 things for sure, and you'll be golden.
If you like it when its done. It was worth it. My swap took me waaaaaay to long. But now that I know exactly how to do it. I could get it done in a day.
Re: Time it takes to do a mini-me swap (mp5o)
i think the only hard part about this swap is the crank pulley bolt... lucky i bought the tool to hold it down
gonna start this swap very soon too
Re: Time it takes to do a mini-me swap (OZ Rally)
I hope all goes well. I am sooo pissed, i got my dizzy off ebay for $70 and one of the necks on the cap is busted, so now i need to go buy a cap.
hey did you bust that cap in yur ***....lol j/p...came to my head like that...i have no idea what im doin....just playin round tho....hope ur swap was smooth...hows it run...was it worth it
Re: Time it takes to do a mini-me swap (burgerbuddy)
here is a pic of my head, its gonna be installed by Sunday hopefully, i am getting the final part in the mail tomorrow (the Oil pressure switch)
good luck to you. dont forget to take the oil orface jet(spelling?) out of the block lol it sucks when you get it all done and it wont hit vtec just because you forgot to pull that little thing out of the block. good luck to you though
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmw626 »</TD></TR><TR><TD CLASS="quote">here is a pic of my head, its gonna be installed by Sunday hopefully, i am getting the final part in the mail tomorrow (the Oil pressure switch)
youre gonna need a vtec solenoid also...
dont forget to use the right timing belt as well..
looks like a z6 head??? so z6 belt should be used.
tell me how much of a difference u feel btw, i want to do this to my car as well
Re: Time it takes to do a mini-me swap (93egsedan)
It took me a couple of days because I had to change my intake manifold and ECU as well (I have a D15B2 on a 93 hatch, European specs). I had to run a total of 10 wires. I finally got mine running right 2 weeks after I got everything installed, that's because I have a turbo also, and that complicates things more. No dyno numbers yet, but according to my butt dyno, this thing is powerfu with only 10 psi of boostl. It pulls so hard, I'm scared it will blow up since my bottom is stock, just ARP connecting rod bolts.
Anyway, plan on spending a whole day on this project, that's if you don't find out that you need a part at 7 pm, when most parts stores are closed, then it will probably take 1 and a half day.
Re: Time it takes to do a mini-me swap (2point3h22lude)
Here are pics of whats progress i have made so far.... Its almost finished...... cant get the crank pulley bolt off. i have a 700lbs Impact wrench with a 1250lbs NBT and it still wont come off
http://bmw626.homestead.com/Index.html
I couldnt get mine off with an impact wrench either. I had to use a breaker bar. Hold on to the front of the car(maybe the bottom of radiator support or somehwere on the frame) with your hands and push the tip of the breaker bar with your foot. Just make sure the car is secure on jackstands, better yet use tires under the car and jackstands.
Re: Time it takes to do a mini-me swap (inline4)
Hopefully my friend brock (H-T Name Brockscivic) is coming over today to finish my swap. he has done 4 of these swaps and i paid him $70 to do it for me cuz i know it would be done right. I cant wait to take it out and run the **** out of it.
Imperious: Mod of Valor
Re: Time it takes to do a mini-me swap (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** »</TD></TR><TR><TD CLASS="quote">The swap will help, but the two biggest helpers to get you from a DX platform to an EX level is the intake manifold and the EX tranny. Get those 2 things for sure, and you'll be golden.</TD></TR></TABLE>
Definitely. Those things can make a HUGE difference.
* B A N N E D *
1 Post
Re: Time it takes to do a mini-me swap (JDM-EJ1)
Yeah, I put a y8 IM on my y7 and could tell the car pulled more at high RPMs, cause the y7 IM sucked ***. The IM on that head looks pretty bad too, the runners arent equal shape/length entirely and the plenum is tiny. that from a d15b2 head or something? look into the y8 Intake Manifold, its the best of all the D series with its huge plenum and short, fat runners.
If you don't change or clean out your crankcase breather the car will smoke. its the big black box on back of motor. i just did this swap last week. have fun
Re: Time it takes to do a mini-me swap (THC1107)
btw, this head will be running higher compression due to the deck having to be shaved 23 thousandths and I am using a y8 2 layer gasket. so my CR will be around 11:1. And i have the EX tranny already.
This swap is worth it, I did it on my brothers 91 crx with a d16a6 block and sohc vtec zc head... its very fun to drive and from a roll and go it keeps up with my b18a1 in my 93 hatch VERY well... but he also has a stage 2 cam and a few other goodies.. just doesnt have the torque from the line like my good ol b series
Did you take 23 thousands off the Y8 head? Does anone know where to find info on how much you can shave off? D15B head and D16Y8 head. i want to do both heads but clueless how much to shave.
I have the Z6 head, I am just using a y8 valve cover. http://www.knology.net/~jediklc/D.htm has some measurements in it but i dont know if thats exactly what your looking for or not.
