throwout bearing question
probably didnt spell that right but any way lol i have a question i have a JDM d15b vtec using the stock P.O.S. CX tranny. i have a stage three clutch, light flywheel and new pressure plate ( all XTD From ebay which other than the bearing going bad the clutch is great if any one was wondering it grabs hard as **** and no slippage) i was wondering, to replace the throwout bearing would it be possible to just use a stock replacment cause if not i really dont know what one to use for it. if any one knows any thing please give me a little advice i am trying to fix this tonight before i go out and want to know if i need an aftermarket high performance bearing because of the clutch set up or can i use a stock replacement
thank you guys for any help it is appreciated and as i learn more about this kinda **** i am more than happy to help out anyone else
Re: throwout bearing question (shanepa2001)
come on man some one has to be able to answer this even tho it might seem like a really dumb *** question to everyone but i dont know and now i am still stuck please give me a little info
a stock one won't be a problem, recommend buying a new one, or if you have a used one lying around grease that bad boy up and put it to work... good luck
P.S.: always replace the throwout bearing BEFORE you put the tranny back on, it'll save you time later
Re: throwout bearing question (thahuhstunna)
ok i just wanted to make sure that a OEM replacment would fit or wou i need an after market one to fit with the clutch set up. i did relace with a brand new one when i installed the clutch but it was the first car i had stick so i guess i fuked it up learning how to drive aka riding the **** outa my clutch lol ow well **** happens
thanks for thye info now i can go get a new one from honda and put it in this weekend
thank u
shane
thank u
shane
